Front axle
Old Dec 13, 2016 | 12:30 PM
2017FSD's Avatar
2017FSD
Front axle
On the stock super duty does anybody's front axle look like it's shifted towards the driver side more if you stand in front of the truck? And if so does anybody know why
Old Dec 13, 2016 | 01:18 PM
Rasalas's Avatar
Rasalas
The front differential has always been on the drivers side in order for the driveshaft to clear the engine, if that is what you are referring to.
One of my friends worships his Chevy. I explained to him that the steering wheel on the Chevy is not perpendicular to the axis of his truck. In order to miss the mechanicals the steering wheels are canted toward the center of the truck. He of course denied it, until I saw him a couple of days later. Now it bothers the heck out of him and he is pizzed I ever said anything.
Old Dec 13, 2016 | 02:36 PM
Teddy O's Avatar
Teddy O
If you're talking about the entire axle (not just the differential), then I would say this is normal. It's an inherent effect with the old-school solid front axle. The track bar pulls the axle slightly toward the driver's side at rest, but the axle centers up when the suspension is under compression. It becomes more noticeable if the truck is lifted slightly without a track bar drop bracket. I also believe the snow plow prep trucks sit higher in the front, making it slighlty more noticeable.
Old Dec 15, 2016 | 12:43 PM
bodytech's Avatar
bodytech
wow I am glad someone else noticed I thought I was crazy. when I put 35/12.50/20 0n my stock rims I noticed there was a difference side to side both front and back One side is perfect the edge of the tire is just about a 1/2 inch beyond the fender on the other side it is about 1/2 inch inside the fender. it is the same front and back. the passenger side in the side that is in and driver out. any clue?
fordman19762003
Jul 8, 2019 12:35 AM
pro1963
1961 - 1963 F100 Unibody
19
Jun 4, 2008 06:26 PM
98infinity
1997 - 2003 F150
May 11, 2007 12:20 PM
imlowr2
Apr 20, 2006 11:36 AM
GrimReaper
Car/truck Buying Advice
Jun 16, 2002 01:32 PM
