Detecting a drop axle
Old Apr 18, 2006 | 10:55 PM
imlowr2's Avatar
imlowr2
Is there a way of telling whether an axle is a dropped axle or the original stock axle? I've been told my axle is a 2" dropped axle.
Old Apr 19, 2006 | 02:41 PM
low54's Avatar
low54
I've been wondering how to check that out as well, I ask the guy I bought it from he didn't change anything out, However, it looks like it comes down quite a bit? The stance doesn't show anyhting though. I think I will still pick up a drop axel from mid fifty though, W/a 4 inch drop. what do you plan on doing
Old Apr 19, 2006 | 09:09 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I would measure from the ground to the center of the spindle and from the gorund to the center of the axle the differnce is the drop. Then get the same meaurements from a stock truck then you will know.
Old Apr 19, 2006 | 10:25 PM
imlowr2's Avatar
imlowr2
My problem is if I measure mine, which may be stock or a drop axle, I'll have to go find another truck which definitely has a stock axle and get permission to crawl under his truck and take measurements. Good advice but there has to be an easier way. Maybe someone with a stock axle could measure theirs and post it on this site????
Old Apr 20, 2006 | 03:12 AM
55forder's Avatar
55forder
Call midfifty or Bobsf100s. They will know the measurements for a stocker. Thats what I did when I had my dropped axle, but its been a while.
Rich
Old Apr 20, 2006 | 07:41 AM
AXracer's Avatar
AXracer
Measuring from the top of the spring pad to the top of the kingpin bushing would be a more uniform and useful measurement. Come on stockers give us a measurement, please.
Old Apr 20, 2006 | 11:36 AM
Phoenixson's Avatar
Phoenixson
Smile
OK, using Ax's method, I'm getting 5.25". I'm about 99% sure its stock. I used a torpedo level and a tape measure. Hope that helps.
