Door locks
Old Dec 13, 2016 | 10:30 AM
BillyBob69's Avatar
BillyBob69
Door locks
So trying to decide on which way to go...
Replace or repair
I checked on Rockauto.com and they have what looks to be generics for about $25/door or $35 for Dorman's.
I have about $60 credit with them after returning some unneeded parts.
Or...repair?
I have read through a few threads on the foil trick for the failing thermal resistor... Seems easy enough. Not sure which way would benefit more. I could always replace then repair the old ones and keep for backups..etc.
Thoughts?
Old Dec 13, 2016 | 12:45 PM
brian42's Avatar
brian42
Veteran: Navy
Personally, I only buy OEM. Over the years I've bought three non-OEM items: radiator overflow bottle with cap (ended up buying OEM 2 months later), driver's door window switch pod (window controls work but auto-down seldom takes the window past 1/2 way), and plastic body pins (don't fit right).
If it was me I would try the repair. If that didn't work I'd buy Ford replacements. I get some of my Ford parts from Rockauto.
Just my .02
Old Dec 13, 2016 | 12:55 PM
Walleye Hunter's Avatar
Walleye Hunter
The repair is not too difficult.
Old Dec 13, 2016 | 01:28 PM
BillyBob69's Avatar
BillyBob69
Thank guys...that's what I needed. Experienced advice.
I did read that it is a pain removing the actuator WITHOUT removing the door handle... Some say not so....
Thoughts?
Also, I have seen everyone saying Tin foil... actual tin foil or would the foil wrap from my wife's cigarette packs work? Those wraps are thinner so I am thinking easier to slide the resistor back in... or does it not matter?
Old Dec 13, 2016 | 05:55 PM
Walleye Hunter
I used aluminum foil off of the roll in the kitchen. Outer door handle came off and I found that it's easier if you pull those plastic things that hold the cables to the door off. I don't know what they're called but they're the nubs that you see when you pull the door panel off. That will let you pull the whole thing farther out the door handle hole to work on it.
Old Dec 16, 2016 | 10:23 AM
BillyBob69's Avatar
BillyBob69
OK Gonna add a little more to this....
The passenger side front door. The plastic pull thing-a-ma-bob to manually lock or unlock the door. What is it called? Couldn't find it on the RockAuto site. Factory part?
Thanks!
Old Dec 16, 2016 | 11:47 AM
brian42's Avatar
brian42
Veteran: Navy
I think this is it:
**** (door latch control rod)
Ford PN F81Z-2521850-AAA (base number is 21850 if you have a dealership parts counter look it up)
Old Dec 16, 2016 | 12:14 PM
empiretc's Avatar
empiretc
just buy generic universal actuators and install them in an easy to get to location.
did this on old green 10+ years ago. paid $20 for the set of 4.
they are still going strong, but if one ever fails, it will be quick and easy to replace. not to mention, CHEAP.
Old Dec 16, 2016 | 12:41 PM
Jesser02EX's Avatar
Jesser02EX
I have to agree with EMPIRETC. I have replaced the rear doors on my Ex with Rock Auto generics and will replace the fronts over Christmas break. I like the fact that FoMoCo units have metal arms on the actuators, but not enough to justify the expense.
Old Dec 17, 2016 | 08:28 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Did my door locks last year... tried the repair, but when I stuck a screwdriver into my finger trying to get taps to bend... that ended that. I bought new ones !
Old Dec 17, 2016 | 12:56 PM
Bill Kay's Avatar
Bill Kay
this is the route I took also. Had one quit working after about a year but after tearing back into it, it turned out to be a broke wire where I soldered the two together. Re solder, heat shrink and we're back golden.
Tip: always extend the heat shrink a minimum of a inch past the joint for support. The copper wire gets weak on the edge of the solder joint and tends to break without some support.
Old Dec 17, 2016 | 05:31 PM
AllaboutMPG's Avatar
AllaboutMPG
As stated before the lock repair is not too difficult. Did mine about 5 years ago. About 6 months in one quit working. Turns out I wadded up the foil when I put the Thermister back in. Used a pair of snips and cut a piece of penny the same size as the thermister. No issues since.
Old Dec 20, 2016 | 08:21 AM
BillyBob69's Avatar
BillyBob69
OK So with everything I have seen here...Gonna go with the new ones, and fix the old ones for backups...or maybe for someone else who needs em. ')
Brian42...thanks for the info. new lock ***** ordered!
Old Jan 7, 2017 | 07:55 PM
BillyBob69's Avatar
BillyBob69
So to close this thread out....
All actuators are replaced now. Just as the other threads stated, the first door takes a couple of hours, then the rest go real quick.
I did remove the outer door handle on the first one but that was it. The others I did with the door handle in place and didn't even disconnect any of the rod connectors. Once you get the first one slid back in, you get a feel for sliding them back in.
I also managed to find the "slot" behind the door latch and used a flat blade screw driver to slide the actuators off of their brackets.
I did however still undo the one 10mm bolt to the window track. Made it easier to maneuver with it loose.
Thanks everyone for the advice!
Old Jan 8, 2017 | 02:24 PM
Walleye Hunter
What actuators did you buy and where did you buy them?
