Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
3 Error Codes
Old Dec 12, 2016 | 11:00 PM
Suprawill1's Avatar
Suprawill1
3 Error Codes
Hi All,
My 05 Escape gave me these codes through an OBDII diagnostic using the ForScan app.
I believe it is one cause causing a trickle down effect. Which one do you think is the culprit?
I ruled out air intake restriction because I took the intake off. I could hear little intake backfires through the intake.
Since this started, I could also hear some kind of air build-up and a release that sounds like a quiet siren that cycles about once every 10 seconds. Generally, I just hear this at idle, not at speed.
Here's what the OBD says:
OBDII w/ForScan
P0190-FF Fuel Rail Pressure Sensor
A circuit malfunction
Possible causes - V-Ref open in harness
V-Ref open in sensor
P2196-FF H02S11 not switching correctly. Sensor indicates rich
Low manifold vacuum on TMAP systems only
High fuel pressure
May be caused by intake air restriction
P2198 - O2 sensor stuck rich - Bank 2 - Sensor 1
Suspect HQ2S21
Dirty air filter
Code may be caused by:
High fuel pressure
Damaged fuel injector
Suspect PCM
Thanks for your thoughts.
Will
Old Dec 13, 2016 | 09:13 AM
ctubutis's Avatar
ctubutis
Yes, this exact scenario can happen.
Ford's general approach to dealing with multiple codes is to begin with the lowest-numbered code first (the fuel pressure sensor in your case)... fix the cavity.
You have a cavity in your tooth, produces code 23.
You have a headache, produces code 86.
Your jaw hurts, code 42.
Fix the cavity and all those things go away.
Be very careful reading & interpreting codes, though... I have never heard of anything with a "-FF" suffix, could that be something that pertains only to vehicles equipped with the Flex Fuel configuration? No idea, do your homework here (myself, I would just take it to a parts store and have them pull the codes for me, I wouldn't rely on any of these third-party thingies).
Old Dec 13, 2016 | 09:52 AM
tomw's Avatar
tomw
I could cut & paste from the other site, escape-city, but go look for yourself.
tom
Old Dec 13, 2016 | 11:51 AM
got2bjoester's Avatar
got2bjoester
I completley agree unless the nearest location to have codes pulled for you is too far to be considered convenient or if the vehicle is DOA and not operable. Even then, I would have a parts store pull codes after I had it running.
Old Dec 13, 2016 | 12:25 PM
Suprawill1's Avatar
Suprawill1
Thanks for your thoughts guys. I'm going to address the FPR sensor first and see what happens from there. If I get stuck, I'll take it to an auto parts store and get a reading from them.
Old Dec 27, 2016 | 01:36 AM
Suprawill1's Avatar
Suprawill1
I ended up changing out the sensor itself and all is well. Running smooth, check engine light off and gas mileage is better.
I figured that siren sound was the fuel pump. It was coming from the area of the fuel tank. My guess is that seeing it had no specific voltage guidance, it was a runaway train. It would cycle from high to low rpm about once every 5-10 seconds.
Thanks for your thoughts peeps.
TrueBlue02
Nov 16, 2015 05:07 PM
ol_red92
Jan 26, 2015 10:18 AM
boogaloo
1978 - 1996 Big Bronco
15
Mar 16, 2011 08:51 PM
ford2go
General Automotive Discussion
Jan 21, 2008 09:37 AM
mpruitt
Aug 12, 2002 08:38 PM
