So i checked the fuses under the dash, all good.
Replaced the relay , no change.
Heated mirrors and rear defroster not working.
The switch on the dash will not light up, so I have no idea if its the switch or something else.
The rear glass was replaced about a month ago and the connections were made back there - I watched the tech do it.
What next to check?
The ice and snow up here is making seeing out the rear window difficult to say the least.
Thanks in advance!
I will be tearing into this issue over the weekend.
Anything else to look at while i've got the trim around the window off?
Are there any items under the hood I should look at ?( relays / fuses for the defroster?)
The side mirrors are from an 2008 , and were not installed by me, so should i start tracking anything down in that regard?
Thanks again
Does your horn work? I seem to recall that the mirrors, rear defrost, and horn all shared a circuit (but it is completely possible that I'm misremembering - CRS syndrome is a bitch!)
