Sunburn
Old Aug 25, 2003 | 10:52 PM
88grandmarquis's Avatar
88grandmarquis
Sunburn
While waxing my truck yesterday under bright sunny skies, I failed to keep track of time. At least four hours in the sun without sunscreen (stupid, I know) and now I'm about as red as my truck. Are there any ways to stop the burning feel, at least for a little while? I once heard that vinegar works, true or not?
It's gonna be tough sleeping tonight.
Old Aug 25, 2003 | 11:08 PM
SCS99F-150's Avatar
SCS99F-150
Sunburn
Noxema helps... The best thing I ever found for sunburn is by Solarcaine. AloeExtra Burn relief Gel. That stuff is a life saver sometimes!
Old Aug 26, 2003 | 01:23 AM
BigMattXXL's Avatar
BigMattXXL
Sunburn
Vinegar works - stinks to high heaven, but it pulls the heat right out of the burn.
We have some green jelly stuff at my house, comes in a big bottle, we keep it in the fridge. It's got Aloe in it and stuff - rub it on, helps the burn a bit.
I keep a bottle of SPF-50 (or 35 - I can't remember) children's sunscreen with me. It's blue until you rub it in, to make sure you don't miss any spots.
Great stuff!
XXL
Old Aug 26, 2003 | 07:11 AM
AegisSailor's Avatar
AegisSailor
Sunburn
I like Solarcaine myself. It's a spray that provides instant relief. Nice and cool!
Old Aug 26, 2003 | 08:22 AM
superrangerman2002's Avatar
superrangerman2002
Sunburn
aloe vera works well too, 100% is best.
Old Aug 26, 2003 | 10:25 AM
wahoo's Avatar
wahoo
Sunburn
Aloe is probably the best thing for a burn, medicaly speaking. But white vinagar takes the sting away better. It's also dirt cheap, unlike pure Aloe. It will stink, bad. I didn't believe it until a few old fisherman at Cape Hatteras got me to try it once.
Old Aug 26, 2003 | 11:11 AM
Mil1ion's Avatar
Mil1ion
Sunburn
Bactine spray!
Old Aug 26, 2003 | 12:17 PM
dragonryder79's Avatar
dragonryder79
Sunburn
a mix of rubbing alcohol and water. take a smal towel big enough to cover the sunburn wet it in the mix wring it almost dry then lay it over the burn. when you start feeling the heat again pull it off and rewet it and do it again.
After doing that for a while it will take most of the heat out of the burn. Then I usually will but something like Noxema before I go to bed. Usually helps pull the last bit of heat out of it.
Thats what I have found works the best for me. Course I only burn once a year and it only bothers me for maybe 2 days then it turns into a nice dark tan that stays with me for most of the winter.
Old Aug 26, 2003 | 12:36 PM
AOGDEN's Avatar
AOGDEN
Sunburn
Try Viagra. It will keep the sheets from rubbing on you while you sleep.
Greywolf
Feb 13, 2010 03:08 PM
mwtmwt
Nov 19, 2004 01:48 AM
FghtinIrshNvrDie
30
Oct 21, 2004 05:14 PM
DPtoo
13
Nov 24, 2002 08:32 PM
