2011 e350 5.4
Old Dec 10, 2016 | 04:55 PM
lineside522's Avatar
lineside522
2011 e350 5.4
Engine knocks real loud on startup for about 2 seconds then runs smooth. Any suggestions.
Thank you
Old Dec 11, 2016 | 09:01 AM
jimbomitch's Avatar
jimbomitch
How many miles?
Old Dec 11, 2016 | 11:23 AM
lineside522
2011 E350 5.4 145,000 k
145,000 K Just changed oil and did not use reccomended filter motorcraft used fram. used fram last time with no problem.
Thanks
Old Dec 11, 2016 | 12:30 PM
lineside522
145,000 k recently changed oil and did not use mototorcraft filter. used fram last time with no
problem.
Thanks
Old Dec 11, 2016 | 06:27 PM
jimbomitch's Avatar
jimbomitch
Have you had it since new? Sorry, I should have asked that with my other question.
Old Dec 11, 2016 | 06:37 PM
jimbomitch's Avatar
jimbomitch
And using the correct weight oil? These engines typically are trouble free. Guessing, it sounds like it could be main bearing(s).
Old Dec 11, 2016 | 09:18 PM
98Econoline150's Avatar
98Econoline150
If you did an oil change then it is because the timing chain tensioner was not upto pressure. If the noise went away, don't worry. If the noise persists I would get it checked out.
I always have filled up my oil filters to reduce dry start problems. 225k and no chain noises ever.
Old Dec 12, 2016 | 01:04 AM
vettex2's Avatar
vettex2
FYI : Fram filters are junk
Old Dec 12, 2016 | 04:30 AM
lineside522
Have not had since 120,000 k. Will try new oil and filter reccomended by OEM, Start with the simple stuff.
Thamks to all!!
Old Dec 12, 2016 | 10:05 AM
Wildman25's Avatar
Wildman25
I'll 2nd and even 3rd that
mattymax
Dec 28, 2018 05:28 PM
tablesaw
Modular V8 (4.6L, 5.4L)
Jun 21, 2012 10:34 AM
jdhudall
47
Mar 12, 2009 10:09 AM
FarmingFord
Sep 22, 2008 06:34 PM
Unglued
Dec 25, 2003 04:54 AM
