2008 E250 LIGHTING
Old Jan 12, 2016 | 07:53 AM
ROADHOGE250's Avatar
ROADHOGE250
Smile 2008 E250 LIGHTING
WE improved the over the road lighting capacity of an E250. text is at
https://groups.google.com/forum/#!to...rd/xQWaFoH2-D8
Old Jan 17, 2016 | 06:23 PM
ROADHOGE250
Improved E250 lighting
photos
http://picasaweb.google.com/10223445...91488748877072
NEW PHOTOS
http://picasaweb.google.com/10223445...72239065002018
Old Jan 17, 2016 | 11:42 PM
thi's Avatar
thi
Originally Posted by ROADHOGE250
How much ws the total cost? Why not just install truck lites?
Old Jan 21, 2016 | 06:44 PM
ROADHOGE250
2008 E250 lighting switch panel
panel photos
the first link malfunctioned try here
http://picasaweb.google.com/102234459580640424681/55002
Old Jan 21, 2016 | 06:59 PM
ROADHOGE250
2008 E250 LIGHTING COST
the 550's are abt $100 pair for 'kit' with relay
relay is $4
90 watt blue white bulb is $14-18 ?
10 ga wire comes in various lengths. See Summit Racing for colors. The top line at Summit, Pica ? is excellent. McMaster Carr sells 100' for less. Very industrial.
10ga connectors at the local auto store run $5 each pack.
and a 2' length of rod at the 550 diameter.
why not LED ? I don't know LED from LED. The 550'S were bought in 2007. Hella works. The LED spectrum is from say $200 a bar up to $1500 for the same looking/length assembly.
Leaving me with no grip and meaningless lumens numbers.
Does the Odyssey charge off a 200 amp alternator with the Kenwood roaring, 5 aux lights, and 2 halogen headlamps burning going south in an Arkansas thunderstorm ?
No.
but we can turn off the lights for an hour.
Old Jan 22, 2016 | 07:50 AM
JWA's Avatar
JWA
Is this some kind of side business for y'all?
Old Feb 20, 2016 | 06:38 AM
ROADHOGE250
2008 E250 LIGHTING
NEW photos of beam pattern
Picasa Web Albums - DATAKOLL MARINE R... - 550
text at
http://groups.google.com/forum/#!top...rd/xQWaFoH2-D8
Old Feb 20, 2016 | 09:35 AM
EagleFreek's Avatar
EagleFreek
I hope not.
Old Feb 20, 2016 | 08:16 PM
ROADHOGE250
12V+ at the roof. Step on the dimmer, lights out. Next adding a fail safe light to direct 10Ga wiring into Hella Conversion headlamps AND designing a headlamp up down motor drive.
The Hella Conversion low beams are seen as normal driving lamps with Ford wiring. Hi beam is a wide angle WIDE ANGLES beam illuminating every deer, owl, ISS, limited by Ford wiring...17Ga ?
Low beam would benefit from a motor drive in load/gas and urban/country/desert. In town the grille is undone, Hella adjusted straight down onto road. Out on the open road, low beams adjusted for middle distance using the 17ga works for .5 mile.
Old Feb 21, 2016 | 08:49 AM
JWA's Avatar
JWA
Originally Posted by EagleFreek
I hope not.
[/IMG]
I'm a bit lost to what this guy or gal posts about----I'm always wondering what we're sharing. Not bashing the effort, just a bit tough to know what we're seeing, how it might work for others etc etc.
Old Feb 21, 2016 | 09:05 PM
tx2sturgis's Avatar
tx2sturgis
Thumbs up let us in on the agenda
Yep...you know most technical articles have some kind of end-point in mind.
I have no idea what this thread is aimed at doing, or solving, or fixing.
It seems to be a moving target. Various statements about wiring and relays but I cant see where the thread is going. I clicked a few links but some of them went nowhere and drive-by malware is always a possibility with this type of thread.
I installed Hella H4 E-code headlamps and Rigid D2 LED driving lamps and I have a LOT of good quality forward lighting on low and high beams.
That's all folks!
Old Feb 23, 2016 | 05:41 PM
ROADHOGE250
2008 Econoline recesed headlamps
are you both driving Ford vans with recessed headlamps ?
I'll post before photos, It is what it is...
with the headlamps installed what wattages and what's the factory wire gauge ?
how's the voltage supply using the computer at bottom page here:
American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength
Old Apr 29, 2016 | 08:18 PM
ROADHOGE250
ALUMINUM...wood lamination failure from aggressive drilling
http://picasaweb.google.com/102234459580640424681/6279150649646358417#slideshow/6279150652967780194
Old Dec 11, 2016 | 12:42 PM
ROADHOGE250
RIGHT SIDE SWITCH PANEL
http://plus.google.com/photos/102234459580640424681/albums/6362913767636828017
Old Dec 11, 2016 | 02:00 PM
vettex2's Avatar
vettex2
are you a vendor?
