Sponsored by: Real Truck
Truck dies when put in gear.
Old Dec 10, 2016 | 09:45 AM
Brandon Smith's Avatar
Brandon Smith
I have an 03 f250 5.4l that I've been having some problems with. When the engine is cold it will drive fine and everything. When it warms up, if I go to put it in gear it just dies right away. Could anyone help me figure out why, thanks.
Old Dec 10, 2016 | 12:49 PM
r2millers's Avatar
r2millers
Do you have an aftermarket type air filter (K&N), etc? It may be an oiled MAF sensor fault is oiled up due to the filter.
That bad data can fowl up a good running engine.
Also, you might check your fuel filter service interval, or a bad fuel pump. They will sometimes start to fail when they get warm. You should see about 45 psi on the rails.
ludude1975
1997 - 2003 F150
May 22, 2025 05:32 PM
Chuckus
Oct 15, 2018 05:52 AM
kruss
15
Aug 24, 2015 01:55 PM
150ford
20
Jan 10, 2009 09:23 AM
nikel
Jan 1, 2008 01:02 PM
