Alternator mystery
Old Dec 8, 2016 | 10:09 PM
kegomatix's Avatar
kegomatix
Alternator mystery
For the years that I've owned this truck, it has done this weird thing with the alternator when I start it.
As soon as it fires up the battery voltage gauge is very low, and sometimes the battery light is on with it. After a few minutes and pulsing idle, it'll go to normal range and the idle smooths out with it.
I've cleaned the terminals and posts several times and it tends to help for a short time but always goes back. When tested with a multi meter, the alternator is not cranking out any amperage when the truck starts. As soon as the gauge goes to normal range, the multi meter is reading the appropriate 14.3-14.5 voltage for charging. I've never seen an alternator take so long to start working properly. Is it the voltage regulator, or is this normal? Like I said, it has been like this for years with no issue but I'd hate it to become an issue as I do use this truck all the time for work. This is the only diesel I've ever owned so I'm not sure what's standard or not.
Thanks in advance for any replies.
Old Dec 8, 2016 | 10:17 PM
ReBilld's Avatar
ReBilld
The gauge is low when it first starts because the glow plugs are pulling a lot of power. When the Wait To Start light goes off, doesn't mean the glow plugs did. When the gauge jumps up to normal is when the glow plugs actually kick off. The battery light being on could be a poor connection on the single wire connector on the alternator. That is the wire for the battery light and sometimes they get damaged from the heater hose laying across them.
Old Dec 8, 2016 | 10:18 PM
farmert's Avatar
farmert
This sound normal to me. The glow plugs can stay on for up to 2 min., and they draw a lot of amps.
Old Dec 8, 2016 | 10:31 PM
kegomatix's Avatar
kegomatix
Thanks guys! That makes me feel better about it, I had no idea the glow plugs are running for that long after startup. Makes complete sense though!
Old Dec 8, 2016 | 11:07 PM
Pest007's Avatar
Pest007
Like the other guys said, the glow plugs continue to draw power after the wait to start light goes off and you start the truck. The ECM will allow the alt to start charging once the load is off from the glow plugs
Old Dec 9, 2016 | 07:59 AM
knottyrope's Avatar
knottyrope
glow plugs draw about 100 amps and your alternator isn't keeping up until they turn off
if you raise RPM up to 1000 does it still do it? at idle you wont get the full power out of the alt
fordbroncodave
17
May 7, 2013 01:16 PM
429poweredf350
Feb 8, 2011 01:47 AM
atomburst
Dec 28, 2010 08:52 PM
jad4
Aug 1, 2008 01:44 AM
bentonmike
Jan 1, 2007 09:18 PM
