Sponsored by: Auxito
Speed sensor
Old Dec 8, 2016 | 08:26 PM
Mike0929's Avatar
Mike0929
Speed sensor
So I'm getting code p0500 the question I have is will the speed sensor on the tail on my transmission cause this code on my 99 f150 4x4 . the reason I ask is because this sensor has been broken off . I'm hopeful it only control's my speedometer and is not related to the code . I've tried to remove what is left however in fear if I get it loose it may fall into the transmission. I will be replacing the speed sensor on the pumpkin this weekend . but sure would like any suggestions on the one on the transmission it's the upper one and is broke off below the surface of the transmission this is a manual transmission .thank you for any help that might be given
Old Dec 9, 2016 | 06:14 AM
Icefan71's Avatar
Icefan71
The sensor on the pumpkin is for ABS.
Old Dec 9, 2016 | 12:38 PM
Bluegrass 7's Avatar
Bluegrass 7
If the missing sensor has an electrical plug it's signal does a number of functions besides the speedo.
If you have up and down shifting issues, that could be one reason.
Good luck.
chris1996
Oct 10, 2016 09:28 PM
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
250K AS
Aerostar
Sep 19, 2011 06:27 PM
Explorer98
May 30, 2006 08:36 AM
nanufree
Dec 19, 2005 12:33 PM
