How much does it cost to
Old Dec 25, 2001 | 02:55 PM
todd88f150's Avatar
todd88f150
Have a shop change your valve cover gaskets. I don't think I have the patience to try it.
Thanks for the info on the PVC valve reroute, did it today. And thanks for the past info on my smog pump problems. I did that mayself too. Thanks and Merry Christmas,
Old Dec 25, 2001 | 04:04 PM
todd88f150's Avatar
todd88f150
Oops, I forgot. 1988 Ford f-150 4-wheel 302 EFI Automatic.
Old Dec 26, 2001 | 09:06 PM
HippieCustoms's Avatar
HippieCustoms
Chiltons labor guide quotes only 3 hours plus parts. If a shop is charging $55 an hour, that's $165 labor. Gaskets required would be the 2 valve covers and upper intake gasket. If you replace the factory ones with the same kind(with the metal reinforcing and o-ring), they are almost $20 each. upper intake is like $3. Most shops would prob get between 200 and 250 dollars for this job. It stuff like this that makes me glad I work on my own. I suggest you get in the mood, and just do it yourself. Don't let it even begin to a test your patience. Just do it and enjoy doing it. Save yourself $150 while your at it. It's better off in your pocket than theirs. Good luck.
Old Dec 26, 2001 | 10:21 PM
bjoern's Avatar
bjoern
Have to concur with HippieCustoms on this one. Done it myself not too long ago and had a lot of fun! Much better than shelling out the bucks...
Old Dec 26, 2001 | 11:33 PM
gamehunter's Avatar
gamehunter
Radi
Jul 4, 2022 02:50 PM
BurchFord
Modular V8 (4.6L, 5.4L)
Apr 22, 2013 02:17 PM
krommag
May 31, 2009 08:43 AM
harold4039
Jun 14, 2008 03:08 PM
71Betsy
Dec 8, 2006 08:46 PM
