Engine Block Heater
Old Dec 8, 2016 | 10:54 AM
  #31
troverman's Avatar
troverman
Originally Posted by DingusKhan
Was reading the manual and saw they recommend plugging in if below -9F. It got really cold here last night, 34F. Have to get my coat out.
Should have saved the $75 and not ordered with block heater. It never has been -9F here.
I believe the previous generation owner's manual recommended plugging in at temps below 10F. That's a big change if I'm correct.
Nope, you did right by ordering the block heater. It's basically an expectation on diesel trucks, even if it isn't necessary.
Old Dec 8, 2016 | 10:57 AM
  #32
Rasalas's Avatar
Rasalas
It used to be that every diesel had a block heater but they never told you that and charged $75 to uncoil the wire and zip tie it to the grill in front.
Old Dec 8, 2016 | 11:03 AM
  #33
linnwgetin's Avatar
linnwgetin
Originally Posted by sky Cowboy
So this doesn't answer your question.
But unless you are required to carry a lot to work, why not walk since its so close by.
I would never drive but enjoy the walk if just a mile or two.
The quickdraw answer would be because it is cold here. ~13 degrees today. But the honest answer is because Im lazy, and bought a 78K truck that I like to drive.
Old Dec 8, 2016 | 11:11 AM
  #34
troverman's Avatar
troverman
Really? I thought in the past all the trucks came with the block heater pre-installed but no cord was included on trucks ordered without it. The extra money would buy the cord and route it.
The new block heater cord is pretty hidden on these new trucks compared to the 16's.
Old Dec 8, 2016 | 11:40 AM
  #35
DingusKhan's Avatar
DingusKhan
You actually bought it twice. They give them to the Yankees for free!!
Damn Yankees....
You also get the electric pre heater. I ordered that too, you know, for when it actually gets below 30. I have thin blood.
But really, I think your base price is higher to pay for that stuff. My Lariat base is $60,390 for F350 4x4 CC. No such thing as a free lunch. Econ 101.
Hope you get your truck soon. Rootin' for ya. Habla Espanol?
Old Dec 8, 2016 | 12:36 PM
  #36
EpicCowlick's Avatar
EpicCowlick
Walk?
Old Dec 8, 2016 | 01:47 PM
  #37
Rasalas's Avatar
Rasalas
On my '01 it was wrapped up tight and hidden in with the plumbing and electrical lines on the left side of the engine. Took two or three trips in to find it but then? Free!!
Old Dec 8, 2016 | 06:09 PM
  #38
coolidge54's Avatar
coolidge54
Someone told me all the engines have the block heaters, selecting the option just gets you the electrical cord when you order that option, any truth to that?
Mine came with the supplemental heater but not the engine block heater.
Old Dec 8, 2016 | 09:39 PM
  #39
Ricohman's Avatar
Ricohman
Forget about the block heater time. You live 1-2 miles from work.
You are filling your crankcase with moisture and all the other problems that go along with running a vehicle in the winter for a couple of minutes.
You really should be walking or riding a bike. Or a small beater car.
Old Dec 8, 2016 | 11:43 PM
  #40
rustyshakelford's Avatar
rustyshakelford
When it's 50 or below I'm plugging in at work. Get down into the 30s and its for sure plugged in all day and night at work. At home, it'll be in the shop to keep the dew from freezing to the windshield. You guys are talking about really cold weather I've only heard about and want to keep it like that.
Brett
Old Dec 9, 2016 | 06:18 AM
  #41
troverman's Avatar
troverman
It won't hurt it - just needs to take it out on the highway for a good warmup on weekends, and maybe change the oil a little sooner.
Old Dec 9, 2016 | 06:47 AM
  #42
Ricohman's Avatar
Ricohman
It was -42 here this morning.
I can't imagine the oil temp would even move after 1 mile.
Old Dec 9, 2016 | 07:17 AM
  #43
troverman's Avatar
troverman
That's a pretty extreme temperature most will never see. Not sure if that's a reading in C or F, but cold either way.
For that much cold, I'd be plugged in all night and idle the truck on high idle for at least 30 minutes before I set off. Nevertheless, the truck can take it. Ford does incredible hot / cold testing - idling 24 hours for 3 weeks straight at -20F (how's that for DPF plugging?); thermal 'shocking' by running at WOT until the engine block is glowing red, then pumping 0F coolant directly into the engine, then running to red hot again, etc.
A lifetime of 2 mile drives in extreme cold will not prolong the engine life, but with more frequent oil changes and some longer runs, I suspect it would still be fine.
btm991
Dec 16, 2009 05:55 AM
tndiesel
Nov 7, 2007 09:22 AM
Futuresweets-10
41
Mar 12, 2007 06:16 AM
Ford Fx4
2004 - 2008 F150
23
Mar 5, 2007 06:31 PM
iceman5
Oct 20, 2004 06:38 AM
