SuperDuty springs in a 79 F350
Here is F350's advice from a while back. Statement #4.
https://www.ford-trucks.com/forums/1...l#post14696824
And more of Ed's info. https://www.ford-trucks.com/forums/1...l#post14696881
Also I am pretty sure the newer SD leaf spring it mounted with a metric bolt? Meaning the bushing is metric too? And the 79 front spring mount bracket holes are standard, same for the front spring, rear shackles bolt.
Does he mind trimming a bit of his front fender fwd lip? Or maybe a small lift (4") and a 1 or 2" body lift, if he does not want to trim anything.
I have a build write up going, I haven't done much in the last few months, it'll be in there when I get to it.. hopefully in the next few weeks.
75fordkid
02-23-2010 09:45 PM
69crewcab
02-07-2007 08:04 AM
