Bad grounds?
Old Dec 6, 2016 | 06:12 PM
greentruck72's Avatar
greentruck72
Bad grounds?
So i was haveing problems with my dash gauges, so i replaced the icvr, now only the fuel and oil presure gauges are acting wonkey could this be a bad sending unit ground, or a short in a wire or something easy?
Old Dec 6, 2016 | 07:18 PM
Tedster9's Avatar
Tedster9
Wonky how? That might be a clue. For example fuel sender can cause the gauge to do the hula, the float is made of soldered brass, they get a pinhole and fuel-logged and sink, or sink halfway and such. Bad engine grounds can also be a cause wonky gauge readings.
Old Dec 6, 2016 | 09:44 PM
PapaBearYuma's Avatar
PapaBearYuma
Very possibly you didn't get the harness plug back into the cluster correctly and fully. Also, the Mylar is very easy to accidentally bend over
Helps to have a good ground strap between cab and engine, too
Old Dec 6, 2016 | 11:23 PM
greentruck72
wonky as only the oil and fuel will go full left or full right and stay there for a while sometimes it works fine, i'd bet i didn't get the plug in great, i got to repull it any way so well see...
Old Dec 7, 2016 | 10:26 AM
HoustonDave's Avatar
HoustonDave
as a suggestion, don't forget to check the grounds at the sending units too.
Old Dec 8, 2016 | 05:33 PM
greentruck72
Tank ground.
The tank has never been out so id be surprised if it was the problem but i will check it, being that oil is on top of fuel in the cluster could it be a bad circut thing on the back of the cluster, does the oil pressure sender have a ground? any other things i should look at while im at it?
Old Dec 11, 2016 | 12:56 PM
greentruck72
so not the tank ground as i tightened it down as it was standing straight up, gauge read 1/2 so i put 5 gallons in it read 3/4 i was like nope it was on half for a week thats not right so i put gas in till it shot back at me 12 gallons later gauge said full i thought yay its fixed then it went to 3/4 now empty, tank sender? btw the oil gauge seems to kinda follow the fuel, bad oil sender?. i think i will replace the oil sender first as it would be easier. then move to the fuel sender.
Hombre427
Electrical Systems/Wiring
Jan 15, 2019 05:24 PM
75Three90
Oct 12, 2015 04:26 PM
mojo79
Nov 15, 2010 07:16 PM
JBoggs
Apr 28, 2006 07:10 AM
pctjk
May 9, 2004 01:28 PM
