Shift rail plugs
Old Dec 6, 2016 | 12:19 PM
sandymane's Avatar
sandymane
Shift rail plugs
I need the plugs for my 95 f150 4.9 manual M50d. I am having trouble locating rubber ones. I spoke with Jegs and they say Dorman part 326-555-074 works for my application. Theirs are steel.
Will steel work or does anyone know where the rubber ones are available? Thank you. Sandy
Old Dec 6, 2016 | 01:25 PM
Mudsport96's Avatar
Mudsport96
If you are set on the rubber ones and can't find them, I just popped my leaking rubber plugs out and siliconed them and pushed them back in. Three years and counting with no leaks.
Old Dec 6, 2016 | 02:06 PM
sandymane's Avatar
sandymane
I had read about that and several have had the same success as you. In the meantime I will see if rubber ones are available. Anyone used the metal ones? I think I will pull mine and check their condition and silicone them If no one knows about the rubber ones or has had success with the metal ones. Thank you. Sandy
Any additional info out there? Thanks
Old Dec 6, 2016 | 03:30 PM
ncranchero's Avatar
ncranchero
I read on one of the forums of using 5/8" wheel cylinder cups. But ????
Old Dec 6, 2016 | 04:10 PM
sandymane's Avatar
sandymane
Yep Lots of sizes are available. These are what the JEGS rep told me work for my truck. Does anyone know if the sizes below are the correct ones?
Dorman Products 555-074
Part Number: 326-555-074
Dorman Products Steel Cup Expansion Plugs 1965-95 Ford
1965-95 Ford
1971-78 Mercury
Diameter: 1/2''
Height: 0.380''
10/pkg
Old Dec 6, 2016 | 08:35 PM
moonley's Avatar
moonley
The size they gave you is too small. Dorman 555-108 is what I used, with a 5/8" nominal diameter and .22" height. You can buy a box of 10 on Rock Auto for $2.50 plus shipping.
Install them the same as an engine freeze plug. They are a nice tight fit; I believe I drove them in using a 3/8" extension with a light coating of Permatex #2 sealant. I would not reuse the rubber plugs if I was you.
Old Dec 6, 2016 | 09:23 PM
sandymane's Avatar
sandymane
I don't mind reusing them but I would rather have new parts. Here is the info from Dorman on part 555-108.
555-108
Steel Cup Expansion Plug 5/8 In., Height 0.220
Application Summary: Chevrolet Spectrum 1988-85, Geo Spectrum 1989
They are the size you mention but not for my truck which really doesn't mean anything for this parts application for what we are using it for. Is your tranny like mine M50d? Are you sure about the number before I order them if I do? NOT second guessing you, just clarifying. Thanks Sandy
Old Dec 6, 2016 | 09:47 PM
moonley's Avatar
moonley
Yes, yes, and yes.
Check out the Motive Gear catalog, page numbers 92-93, illustration #20: https://www.motivegear.com/wp-conten...SCAT_004_1.pdf
Old Dec 6, 2016 | 11:17 PM
sandymane's Avatar
sandymane
Thanks for the help and thank you for the link. When you did yours was there a gasket for some kind of door thing I read about that you have to remove. I'm not sure it was for our tranny but I think so and they said to replace the gasket.
Old Dec 7, 2016 | 08:01 AM
moonley's Avatar
moonley
Read this: https://www.ford-trucks.com/articles...ative-measure/. The only note I have is that leaving it in neutral is fine as long as you have it in neutral when you reassemble.
Old Dec 7, 2016 | 10:50 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I installed the replacement metal plugs from Allstate Gear (I think) a couple years ago and still leak-free.
X2 on the comment to put the transmission in neutral. I followed the advice found in several on-line sources to leave it in gear and that gave me issues on re-install. Put it in neutral and it goes back in neutral and all is well.
Old Dec 7, 2016 | 01:05 PM
sandymane's Avatar
sandymane
Great info guys. I am ordering them today and will let you know how it turns out. Thanks for the help and advice. Sandy
Old Dec 10, 2016 | 06:51 PM
ncranchero's Avatar
ncranchero
Question: Supposing you were to have the OEM rubber plugs to install, would you think it could be done from underneath instead of through the floor? This post got me thinking of alternative parts and methods since I need to replace mine as a precaution.
1- I happened upon a well nut that got me pondering them as a replacement, using a washer on the head to make it swell properly. The pictured one is a 3/8 when a 5/8 would be needed.
2- I removed the OEM plugs from a spare top cover and cleaned them up. They are surprisingly great condition so I plan on replacing mine with them. I snapped a pic for reference.
Been busier than a one-armed wallpaper hanger so I haven't crawled under my truck to look for myself. Thought I'd get some opinions from you folks.
TN_Splash
1983 - 2012 Ranger & B-Series
Oct 19, 2008 11:14 PM
wordmaster
Jun 13, 2008 03:21 PM
WATTSUP!
Oct 14, 2007 02:12 PM
RangerPilot
Mar 27, 2006 10:24 PM
Highboy70
Feb 11, 2003 08:56 AM
