What is this cable for??
Old Dec 6, 2016 | 11:04 AM
Josh Schaffrin's Avatar
Josh Schaffrin
Just bought a 2013 Ford F250 6.7 Powerstoke with 115K miles and it has this cable coming from below the middle of the dashboard. Not sure what its for. Possibly a winch or something? I know it used to be a commercial vehicle. Anyone know??
Old Dec 6, 2016 | 11:09 AM
Just Strokin's Avatar
Just Strokin
have you tested it to see if it has voltage?
Could be for a high wattage amp or ham radio unit.
What ever it was for is for high amp/wattage unit.
Old Dec 6, 2016 | 11:41 AM
06greenstroker's Avatar
06greenstroker
Possibly a 3rd Battery hookup for some extra equipment they may have had. Battery was in the cab?!? Have you traced out where the other ends of the wires go to/connect to?
Old Dec 6, 2016 | 11:48 AM
senix's Avatar
senix
my guess is emergency radio equipment. You will want to get that out of there so you don't risk energizing it and shorting something.
Old Dec 6, 2016 | 12:05 PM
Chad149's Avatar
Chad149
Definitely aftermarket. My guess is they had a large power inverter in the cab.
If no immediate plans to use them assure they are disconnected at the other end or remove entirety.
Old Dec 6, 2016 | 05:47 PM
PlayersZ28's Avatar
PlayersZ28
Looks like the cable is much heavier capacity than that switch could handle. It has two different color wires either side of the switch in the picture so it must be switched. Could still carry 10-15A or so.
Googs81
Mar 9, 2020 11:47 PM
78Ranger_GARedNeck
Jun 6, 2008 11:39 AM
Nickmont
Electrical Systems/Wiring
Sep 11, 2006 06:12 AM
cluth1962
16
Mar 5, 2006 08:12 AM
