crown vic engine location
Old Dec 5, 2016 | 02:48 PM
jc302x's Avatar
jc302x
does anyone know the right offset for engine placement with the crown vic front end.. i looking for side to side i don't think is supposed to be centered do to the rear end been so far off to the pass side, the most i can go is 1 3/8 over to the pass side
Old Dec 5, 2016 | 04:28 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I don't know if the Crown Vic makes a difference, but from the factory, the engines in the F series are offset 1½" to the passenger side (crankshaft centerline).
Info from the Ford body builders manual.
Old Dec 5, 2016 | 06:37 PM
jc302x's Avatar
jc302x
Originally Posted by mikeo0o0o0
I don't know if the Crown Vic makes a difference, but from the factory, the engines in the F series are offset 1" to the passenger side (crankshaft centerline).
ok i wanted to set the engine the same way my old 360 was before but i forgot to messure before i pulled it out.. thank you
Old Dec 5, 2016 | 06:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My memory sucks. I dug out the manual and checked, it's 1½" not 1".
I corrected my original post.
Old Dec 5, 2016 | 10:14 PM
HIO Silver's Avatar
HIO Silver
FYI.. the engine offset kinda matters if ya install oval-bodied mufflers..
Kinda threw me for a loop when I hung some spare Flowmasters in place and it got real close to right frame rail.. then the lightbulb came on about the engine offset..... I went with round-bodied Magnaflows instead.
Old Dec 6, 2016 | 12:27 AM
jc302x's Avatar
jc302x
ok thanks for checking for me
Old Dec 6, 2016 | 12:29 AM
jc302x's Avatar
jc302x
i think the part that matter the most is lining up the trans tail shaft to the rear end, which has more offset than the engine
njturp
1947 and Older Ford Trucks
Jul 15, 2019 08:01 PM
Nick Hammerschmidt
2015 - 2020 F150
30
May 7, 2019 01:32 PM
ymirr
Mar 28, 2009 05:28 PM
