I just purchased a 1975 F150 4x4 4 speed with a recently built 460 with the below specs:
Block: DIVE-6015-A2 +.040"
Head: DOVE - C 2.09/1.65
Piston: Aluminum 8.5 to 1 cast
Crank: 2YABC 10/10
Rod: C9AE-B
Cam: Unknown Hyd - 262/272, .484"/.510", lobe center 106/118
Advanced +4* crank sprocket
Edelbrock Performer intake and 600 cfm carb
Engine seems to run fine and will be used for hunting off road . Is the carb too small? Cam OK? Don't need a thumper, smooth rv running is fine for this retired guy! A guess at hp/tq? Supposed to get 10 mpg.
