Bully Side Steps
Old Dec 6, 2016 | 12:28 AM
wyrm73's Avatar
wyrm73
Originally Posted by somethingclever
yes I have used these same ones located just as you describe.
Nice and sturdy - no issues.
Mine are mounted pretty much the same as described by BigSexy78 and somethingclever. I am pretty sure mine are the same model as the ones linked, if not they sure look identical and the ones linked should work. I attached some pictures if that helps. It's kind of hard to tell from the pictures, but the top bolt is right up against the underside of the sheet metal that forms the door frame. The stock hole in the step was about 1/4- 1/2" higher and is pretty visible on the left side of the first picture. If you look closely, you can also see the crease in the sheet metal for the door frame too. I wanted to use 5/16" hardware for both bolts, but they are pretty close together and I decided to stick with the original drilled 1/4" for the top one so that I didn't weaken the step mount too much. The aluminum is thick, but I didn't want to risk it breaking.
Old Dec 6, 2016 | 11:37 AM
Matt1966's Avatar
Matt1966
Excellent pictures and description !
Yes, I agree it's the model AS-600. I was going to buy he AS-200 but it has totally different mounting so I am very glad I asked you!
Thanks a lot ! ! !
Mats
https://www.summitracing.com/int/parts/plt-as-200
Old Dec 6, 2016 | 12:58 PM
BigSexy78's Avatar
BigSexy78
That is how I mounted mine wyrm73 except I also added another bolt to the side. I drilled thru the step mount and into the crossbrace just to help reduce the torque on the pinchweld. Works great and I am 290 lbs.
Old Dec 7, 2016 | 09:13 AM
skidoodave's Avatar
skidoodave
I have these same steps on my 78 mounted the same way. I'm a tad over 300 and they hold up great. I wouldn't stand on them with my full weight and bounce up and down but for a quick helping step they're perfect.
Old Dec 8, 2016 | 12:21 AM
N2S3's Avatar
N2S3
Aren't there any problems due combining Aluminium and steel?
Meaning, that this combination result in real Bad rusting the Steel as you can observe in Landrovers for example. These have a steel chassis, steel screws but an aluminum body and they rust everywhere.
Old Dec 8, 2016 | 04:26 AM
Matt1966's Avatar
Matt1966
Yes, galvanic corrosion could sometimes be a problem. I think it's quite easy to
avoid here because the contact areas betweeen steel and alu is small. Can be a good idea to coat the contact areas with paint, both the upper part of the Side Step, the predrilled holes and the small 2 areas in the body that makes contact with the Side Step. You can also use the sacrificial anodes (zink) often used on outboard engines but I think it's overkill here.
N2S3. Thanks for reminding us! I had absolutely no thoughts about this problem before you mentioned it.
Mats
Ps. If you dont understand my english, just let me know and i will try to explain better.
Old Dec 8, 2016 | 04:52 AM
N2S3's Avatar
N2S3
excellent description, I think that's the way to avoid any damages.
The used screws or rivets may cause electric connections too.
But these steps are a nice invitation for the girl friend to enter a lifted truck...
There is a seven year old boy too who has to climb inside.
The truck isn't already here, she is waiting to be shipped out of Jacksonville.
Old Dec 8, 2016 | 09:13 AM
classictruckman's Avatar
classictruckman
It's a bit Canadian redneck, but if you put a piece of duct tape on the steel anywhere the aluminum contacts it that will prevent corrosion between the 2 metals.
Old Dec 8, 2016 | 09:30 AM
HoustonDave's Avatar
HoustonDave
or maybe paint the contact surfaces with that rubberized brush-on insulator they sell in hardware stores.
Old Dec 8, 2016 | 01:10 PM
CelticOne's Avatar
CelticOne
Regular User
Wouldn't that be RedGreenNeck?
We hold these two pieces together using the handy mans secret weapon, Duct Tape
-Red Green
Spare the Duct Tape, Spoil the job.
-Red Green
Bow your heads for the men's prayer.
(group recites)
I am a man, but I can change.
If I have to, I guess...
-Red Green
If women don't find you handsome, they can sure find you handy.
-Red Green
Old Dec 8, 2016 | 06:36 PM
classictruckman
I've done work for a company that builds tanker trucks, the majority of those tanks are aluminum. The welders there swear by duct tape for preventing galvanic corrosion, they've tried all sorts of different coatings which were designed for just that and duct tape works better.
Old Dec 10, 2016 | 06:49 AM
rob8210's Avatar
rob8210
I have the same steps on my 79 f250 4x4. I just put a small piece of an old mudflap in between the aluminum and the steel
Old Dec 26, 2016 | 06:09 PM
  #28
BigSexy78's Avatar
BigSexy78
I put a 12 inch long strip of white LEDs above the steps. Now when you open the door they light up. Now the wifey can get in safely at night. Happy Wife Happy Life!! I have to admit I like them lit up too.
Old Dec 26, 2016 | 11:22 PM
  #29
skidoodave's Avatar
skidoodave
Nice, I might have to do that too.
Dagwood_55
Jan 25, 2018 10:23 AM
orangeford
Mar 25, 2015 06:48 AM
beanhead6D5
Aug 15, 2013 07:36 PM
76f350spercamprspeal
Aug 3, 2009 07:15 PM
masterbeavis
Feb 1, 2009 06:49 PM
