Fuel line removal
Old Sep 12, 2004 | 07:13 PM
MustangGT221's Avatar
MustangGT221
Fuel line removal
Ok so I need to take the two fuel lines off the rear of my engine (taking the engine out).
They have two (1 big/1 small) couplers behind the motor, one to the fuel rail and one to the FPR that need to be disconnected. I know you need a special tool to remove the lines, is that tool only available from ford (I ahve the # for it) or can I use a tool from another store?
Any tips or special techniques in helping me remove these lines once the pressure is bled?
Old Sep 13, 2004 | 07:55 PM
jwtc36's Avatar
jwtc36
Talking
You don't need to buy the tool from Ford.....any parts store will have it. Too bad you aren't closer to me....I'd let you borrow mine
It's been a few years since I had to mess w/ those lines. The set I have is called a spring lock coupler release tool. I think there are 5 different sizes in the set I have...Red,Blue,Black,White and Yellow.
Can I make a suggestion???
Replace the FPR while you have easy access to it. It's a real PITA to do in the truck.
Old Sep 13, 2004 | 08:52 PM
MustangGT221
I will take that suggestion and do it....but yeah they're the same kind of couplers you mentioned.
Old Sep 13, 2004 | 08:57 PM
LxMan1's Avatar
LxMan1
Autozone has a complete set of plastic ones that works great. Their under $10
Old Sep 15, 2004 | 02:59 PM
Blurry94's Avatar
Blurry94
Spray a generous amount of WD-40 or other penetrating lubricant on the fuel fittings and let it sit for an hour or so. I sprayed mine and let it sit over night. The next day I pulled them apart with the plastic separator with very little effort.
I also pulled the fuel line off of the fuel filter and drained the excess fuel out of the line and into a glass jar to help minimize the mess.
Old Sep 16, 2004 | 03:31 PM
MustangGT221
OK I got the little metal tool from napa and will have a go at it ...thanks.
Old Sep 16, 2004 | 08:25 PM
MustangGT221
The napa tool worked fine, 15 bucks, and I got the lines off in about 2 minutes. Very easy..thanks
Old Sep 25, 2004 | 10:17 PM
alabamabuddog's Avatar
alabamabuddog
You could have just pulled the fuel rail off the injectors and tied them back out of the way. Your going to pull it off the motor anyway.
Old Sep 26, 2004 | 04:31 AM
MustangGT221
Well, if I wasn't pulling the motor then yes I'd agree...but when pulling the engine you want all that stuff outta the way
Old Sep 26, 2004 | 07:19 AM
alabamabuddog
I pulled my motor and tranny together and I pulled rails and tied them back and the compressor. I left the Alt and the air pump on also. You dont have to pull everything off just top ull the motor.
