Fuel injection line
Old Nov 28, 2008 | 01:36 PM
straightsixer's Avatar
straightsixer
Fuel injection line
Can someone tell me how to remove the fuel injection lines from the injectors? I am removing the manifold and can't figure out how that part comes apart, the manual mentions a special tool?? All I want to do is dismantle the injection enough to lay it out of the way while I pull the manifold.
Old Nov 28, 2008 | 01:37 PM
quicklook2's Avatar
quicklook2
any auto parts store will have the tool needed to do this.
Old Nov 28, 2008 | 02:19 PM
Conanski's Avatar
Conanski
The fuel rail just unplugs from the injectors once you remove the 4 bolts holding it to the intake. But if you are trying to disconnect the rail from the fuel lines then you need a pair of special tools(2 different sizes) that insert into the connector near the firewall so they can be pulled apart.
Old Nov 28, 2008 | 03:35 PM
paintslinga2010's Avatar
paintslinga2010
I went and got the tool. Brought it back and tried for 3 hours to get it to work. I eventuallygot sick of it and unbolted the fuel rail and pulled the rail off the injectors.
