I just put the same kit on mine a couple of weeks ago. I still have factory rear springs, and I probably have close to two inches of threads showing on the u bolts. The factory ones had about a half inch.
I know this is an old thread, but I found it doing a search for info. Last week I ordered a set of 4" flat blocks and U-bolts from SDSprings.com, and I installed them today. Upon removing the stock blocks I realized that they are tapered. I ordered the flat blocks as I was under the impression that only the longer wheelbase trucks needed the tapered ones. I installed the new blocks anyway since I was sick of the front end sitting higher than the rear for the last 2 months due to my X codes. Will this hurt anything? Am I going to need to buy tapered blocks instead? Tapered shims? Thanks in advance for any help.
Inquiring minds want to know. I'm replacing a lift on mine and removed tapered lift blocks. Bought an angle finder but don't know what the angle is supposed to be.
If you have a double cardin setup the angle between the pinion and driveshaft should be between 0 and 2 degrees or so. The closer to 0 the better. In other words a straight line from pinion to driveshaft up to DC joint. That DC joint takes all angle.
If you have single u joints at each end of driveshaft the angle between the rear pinion and driveshaft should = the angle between the transfer case out put shaft and driveshaft.
