Rear blocks
Old Sep 20, 2017 | 10:43 AM
Stewart_H's Avatar
Stewart_H
I could have swore I had the info saved on my computer but I can't find it.
Someone once posted a chart of which wheelbase configuration gets which block size block and if it's tapered or flat (I think it was in the SuperDuty forum), but I can't find it now.
I hate my etch-a-sketch brain.
Stewart
Old Sep 20, 2017 | 02:50 PM
Silverback01's Avatar
Silverback01
Drove fine
Drove the X to work and back today. 20 min one way, mostly 70-75 mph. No vibes. Can I install tapered wedges under the block (or between the block and spring) to adjust pinion angle, or would I have to get tapered blocks, if I need them?
Old Sep 22, 2017 | 08:41 AM
Silverback01
I was wrong
While driving the X to work today, with radio off this time, I can hear a droning noise coming from rear end that wasn't there before. Can't really feel it, not like I could when I lifted my TJ 5" in the rear and had really bad vibes. Happens around 70mph, just like someone posted earlier. So, can I just add steel shims, and if so , do they go under block or on top of block? Or do I need to get tapered blocks instead? I can probably bring the blocks to work and have them milled to a taper. Are 4" tapered blocks 4" on thick end or thin end? Help!
Old Sep 22, 2017 | 09:53 AM
rock2610d's Avatar
rock2610d
Do you have a double cardin joint or single joints?
You need to do some measuring....
Typically if you lift a DC setup you have to increase the angle of the wedge over factory angle.
If you have a single joint setup no changes in angle over factory are needed when lifting......up to a point.
We need to know if you have a DC or single setup to be of much help.
When I did mine I put clamps on my springs and loosened the bolt that holds the springs togather and added the wedge to spring pack with a bolt holding it and springs togather.
Old Sep 22, 2017 | 10:30 AM
Silverback01
Driveshaft
Did excursions come with either, or do you mean in case someone changed it to DC?
Old Sep 22, 2017 | 10:53 AM
rock2610d's Avatar
rock2610d
Some came with a double cardin, and some came with a set of singles.
You could have either from the factory.
Old Sep 22, 2017 | 02:39 PM
Silverback01
I was unaware of this. I'll go look.
Old Sep 23, 2017 | 08:32 PM
breezy5000's Avatar
breezy5000
Has anyone ever figured out why some have a DC driveshaft and others don't?
Old Sep 23, 2017 | 10:02 PM
rock2610d's Avatar
rock2610d
My theroy:
Most 2000s have singles.
In 2001 and up I think if you have limited slip you probably have a DC.
Old Sep 23, 2017 | 11:10 PM
breezy5000's Avatar
breezy5000
My theroy:
I have 05 V10 3.73 limited slip and singles.
Old Sep 24, 2017 | 10:29 AM
Silverback01
DC it is
just went out and looked under X, finally. It is a DC driveshaft after all. I'll have to check the angles of the tcase and the pinion next, but I can clearly see that the pinion is almost parallel to the ground. From owning a TJ and modding it for years (before I took a loss trading it on the X) I know that the pinion angle and the driveshaft have to be in line, maybe pinion down a degree or two due to rotation of pinion under load. Looks like I'll have to get shims to install in the rear. Also I have cut down front secondary springs to add in as AAL as well. The 4" blocks made the X exactly level, now I want the rear up just a little over the front. Just like my Jeep, the mods never seem to end.
Old Sep 24, 2017 | 01:48 PM
WE3ZS's Avatar
WE3ZS
My theroy:
Or not......
Mine is the same.
Old Sep 24, 2017 | 04:19 PM
  #28
Silverback01
01, XLT, 6.8, 3.73, not sure about LS.
Old Sep 24, 2017 | 08:17 PM
  #29
Misky6.0's Avatar
Misky6.0
My theroy:
Could it be diesel vs. Gas and/or 2wd vs 4wd?
Old Sep 24, 2017 | 08:32 PM
  #30
rock2610d's Avatar
rock2610d
Well, darn.
My theroy is shot.
Both my 2000s are singles....1 is XLT 1 is Limited 1 is limited slip one ain't. 1 has 4.30 gears and 1 3.73 both came with singles.
My 2001 is a XLT, 3 73 4x4 limited slip......it has a DC.
all 3 are 6.8L V10s.
Maybe it's a HD tow package thing?
Maybe gearing and LS are reasons. I have no clue at this point.
