Hydroboost conversion.
Old Dec 2, 2016 | 07:08 PM
wils3825's Avatar
wils3825
Hey guys. I'm working on hydroboosting my '95 F250. I'm using stock F-superduty master cylinder, and booster. My lines are just parker hose with JIC fittings. Does anyone know of a source of an afternarket F-Superduty brake pedal? the stud where the pushrod connects is in a different spot, and I'd rather replace this than pull it all apart to modify it.
Old Dec 2, 2016 | 07:15 PM
Bob_T's Avatar
Bob_T
When I did my hydroboost I read several reports that they're no longer available from Ford and the only place to find one is junkyards. I went ahead and modified my pedal. Not much of a job if you have a drill press and welding capability. If you don't, then a serious junkyard search is probably in order.
Old Dec 2, 2016 | 07:21 PM
ReBilld's Avatar
ReBilld
Doubt you will find one aftermarket. Junkyard will probably be your best bet. A gas F-Super Duty pedal will work too.
Old Dec 2, 2016 | 11:22 PM
wils3825's Avatar
wils3825
Seems about right. Thanks, guys!
mckoloum
May 16, 2019 03:53 PM
Mr. Ed
Jun 24, 2016 02:26 PM
f-100 rick
May 29, 2016 07:29 AM
misfit36
Aug 25, 2008 08:09 AM
Junior
Aug 13, 2003 04:21 AM
