It is always the condenser
Old Dec 2, 2016 | 03:30 PM
Gotanoldtruck's Avatar
Gotanoldtruck
So my 1948 F5 stopped running the other day. It had been sitting for a month. I tested everything and could not come up with the problem, so I replaced the gas (its was old), the spark plugs (not old), the distributor cap (it was original), rebuilt the carb, and swapped out a few other things. Nothing changed. So I replaced the condenser (which had tested fine) but the wire insulation had rubbed off as it came into contact with the distributor plate (which moves with the vacuum advance). See picture. Anyway, I knew better and yet it was not the first thing I did. So $1.50 part and about 30 seconds of time would have solved my problem.
The silver lining is that it starts up every time now and runs well.
Old Dec 2, 2016 | 03:42 PM
pbsdaddy's Avatar
pbsdaddy
So true. Years ago, 1966, I had a 1935 Ford 3 window coupe. My first car after high school. Everything was fine, (except for my girl friend who hated it), until I started having starting issues. I could push start it, but using the starter only produced engine turn over.
I finally got frustrated and sold it, (for next to nothing), and bought a 19641/2 Mustang.
I sold the 35 to a friend. A few weeks later, I saw him at a drive-in theater. My girl, (happy with the Mustang), and I walked over to talk with him and his lady. I asked how he had been able to start it without issues. He smiled and said, "I replaced the coil"!
I'd like to have both those cars back. But I will never allow a coil to stall my progress on any car again.
Old Dec 2, 2016 | 03:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
At least the other things you did weren't a waste of time !
Old Dec 2, 2016 | 06:33 PM
firstrider's Avatar
firstrider
Don't feel like the Lone Ranger , Tonto . Spent over $600.00 & many hrs. chasing the same problem March of this yr. With all the new parts the truck runs like a well oiled Singer . Have no regrets .
Old Dec 3, 2016 | 08:01 AM
pweng1's Avatar
pweng1
For a short while i worked at a shop that played many practical jokes on each other. One of their jokes was to toss a charged up condenser across the room for the new guy to catch.
Old Dec 3, 2016 | 08:09 AM
hiball3985's Avatar
hiball3985
If you have a problem again in a short period of time don't be surprised, the off shore made condensers are crap, some are dead right out of the box, a very common problem these days..
Old Dec 3, 2016 | 09:12 AM
artscott61's Avatar
artscott61
Veteran: Navy
I just did that with my electronic (77 ford) in the 55 ignition. One day thankfully in the garage at home it just would not start no fire I tried a coil but to no avail finally I replaced the electronic box and put on new pigtails as the p o had cut them all off. Still no start then I tried the new coil again and bam it started. I am learning the electrics of this stuff out of necessity .
Old Dec 3, 2016 | 11:21 AM
tractormanbill's Avatar
tractormanbill
tractorman
I have found on old tractors which has the same electrical stuff as cars:
If the points are set correctly, the coils give very little problems unless the key is left on with the points closed and it is usually best to leave the old condenser alone as it is usually a better unit than a new foreign replacement!
TractormanBill
Old Dec 4, 2016 | 01:52 PM
CBeav's Avatar
CBeav
Being shorted to ground is one thing but I've learned over the years that bad condensers make the exhaust fumes burn my eyes.
Old Dec 4, 2016 | 01:56 PM
Tedster9's Avatar
Tedster9
"Pink spark", oldtimers said bad condensor. Hm. Same thing I bet - stinky exhaust.
Lakotas53
Jun 3, 2012 09:27 AM
DConcepts
General Automotive Discussion
May 16, 2008 10:12 PM
1994 Ford MN
1983 - 2012 Ranger & B-Series
26
Apr 5, 2006 11:29 PM
jcarker
Nov 7, 2003 02:13 AM
jamshell
Oct 28, 2003 08:56 PM
