Will not start
Old Dec 2, 2016 | 01:19 PM
Dparry's Avatar
Dparry
Will not start
I have a 97 f250 7.3 powerstroke we replaced the engine in in with a running engine, we get the engine in the truck we get it all hooked up all the sensors are new, rebuilt the injectors brand new glow plugs new starter but now she won't start we tried a little bit either but she backfired please help I need this truck to go down to fire academy
Old Dec 2, 2016 | 01:32 PM
Jarrett Campbell's Avatar
Jarrett Campbell
Did you rebuild your own injectors or send them out??
Also, follow this.
https://drive.google.com/file/d/0Byb...1qRU1VVGc/view
Check your IPR plug and any other plugs you disconnected to install the new engine.
Old Dec 2, 2016 | 01:46 PM
Dparry's Avatar
Dparry
We sent them out
Old Dec 2, 2016 | 03:38 PM
farmert's Avatar
farmert
If you have had the injectors out, it can take several minutes of cranking to get oil back into the rails, and pressurized, so the injectors will fire.
Old Dec 2, 2016 | 04:04 PM
Dparry's Avatar
Dparry
We have oil in the right areas fuel in the right areas and getting air in and the glow plugs are plugged in
Old Dec 2, 2016 | 05:25 PM
z31freakify's Avatar
z31freakify
Stop spraying ether its going to damage your engine, as Tom mentioned is just air in the HPO system and air in the fuel system. Make sure your batteries are fully charge and make sure your voltage don't dip below 10,5 volts when cranking.
Old Dec 2, 2016 | 06:54 PM
ReBilld's Avatar
ReBilld
Keep a battery charger on it and crank 10 seconds at a time waiting 3-5 minutes between cranks. Much more than that and you could burn the starter up. I have had to do this as long as 2 hours on some trucks to get the air out of the HPO system after having injectors out.
Old Dec 4, 2016 | 09:12 PM
fordman67's Avatar
fordman67
wants help yet AWOL for 2 days..
Old Dec 5, 2016 | 08:50 AM
knottyrope's Avatar
knottyrope
OP might be reading the email copy of the replies
sand_fiend
107
Sep 26, 2022 07:47 PM
Christopher Bary
Jul 2, 2016 11:19 PM
joker67735
Sep 12, 2013 09:28 AM
Nero Morg
Oct 13, 2012 08:29 PM
rockcrawler_101
Aug 4, 2012 07:06 AM
