02 f250 shaking issue
Old Nov 30, 2016 | 10:01 PM
Leto236's Avatar
Leto236
4wd Low
I have a shaking issue only at 40 mph + only while i am braking. I thought warped rotors, but the pedal isn't pulsing and if they are warped, wouldn't it do it every time regardless of the speed??
My second thought was the center support bearing. It had some movement so I replaced it tonight. Now there isn't any movement in the drive line. After a test drive, it hasn't gone completely away. It is still barely there.
I am not sure where to go next.
What do you guys recommend?
Old Dec 1, 2016 | 08:54 AM
knottyrope's Avatar
knottyrope
if 4WD remove rear drive shaft and see if it does it still in 4WD
Old Dec 5, 2016 | 09:48 AM
GEugeneS's Avatar
GEugeneS
Although there could be several things in play, I too developed a shaky front end on my 2WD F350 and suspected shocks or wheel balance or... Ford said it was the steering damper. With not much spare time, I let them replace it. Problem solved. Something to consider
Redneckmorton
Aug 23, 2017 08:55 PM
clear1987
Sep 25, 2012 09:57 PM
Resendiz
Apr 3, 2011 11:02 PM
n.o.yat
Jul 27, 2008 09:07 PM
88BigGuy
Jan 22, 2003 03:06 PM
