The L73 10 5 9J22 should be 3L73 (3.73:1 Limited slip) 10 5 (10.5 inch ring gear Visteon rear axle). I think you're missing the first number on the bottom line.
In fact if the truck is a superduty I know that's what it is (except for the limited slip) because that's the only axle ratio the PSD's are offered with.
Unless you have a dually F350 and then you can get either the 3.73 or the 4.10.
Originally posted by johnsdiesel Unless you have a dually F350 and then you can get either the 3.73 or the 4.10.
But he doesn't have a dually. He has the SRW 10.5 which is only available with 3.73 in a PSD
I was only talking about his truck specifically. That's why I mention Superduty by name because I don't know if the PSD vans are offered in different ratios.
My truck has a blank space under AXL on the pillar as well. Looks like it was printed that way from the factory. However I know my vehicle had been modified before I bought it because the numbers on the diff tags read that I do not have posi. and I sure DO have posi. Also I am pretty sure that 3.73 was not the only axle ratio available on superduty f-250s from the factory, now this may vary depending on the year. The Ford truck FAQ at the top of this forum has a link to a calculator where you can get an idea of your gear ratio by inputting your rpms at 60 mph ( maybe tire size too).
Originally posted by backnblack00 Also I am pretty sure that 3.73 was not the only axle ratio available on superduty f-250s from the factory, now this may vary depending on the year.
For SRW PSD's it was. For gas motors or duallies there are other ratios. Unless this has changed in the new 04's.
