Sponsored by: Real Truck
Missing Axle codes
Old Aug 25, 2003 | 02:35 PM
freefam's Avatar
freefam
Question Missing Axle codes
thanks for the post on vin decipher, but now I can't find the axle code. Not on the door sticker. axle tag says:
S 409 F
L73 10 5 9J22
Truck is 4x, , PSD, LWB, CS (I think), SC, F250
Who knows?
Thanks
Old Aug 25, 2003 | 03:50 PM
RRMike's Avatar
RRMike
Missing Axle codes
The L73 10 5 9J22 should be 3L73 (3.73:1 Limited slip) 10 5 (10.5 inch ring gear Visteon rear axle). I think you're missing the first number on the bottom line.
In fact if the truck is a superduty I know that's what it is (except for the limited slip) because that's the only axle ratio the PSD's are offered with.
Old Aug 25, 2003 | 04:40 PM
freefam's Avatar
freefam
Missing Axle codes
Thanks, I figured out by jacking up the truck. It is LS3.73, The first owner said it was not, but he was wrong-- Good for me!
Old Aug 25, 2003 | 04:56 PM
johnsdiesel's Avatar
johnsdiesel
Missing Axle codes
Unless you have a dually F350 and then you can get either the 3.73 or the 4.10.
Old Aug 25, 2003 | 05:34 PM
RRMike's Avatar
RRMike
Missing Axle codes
But he doesn't have a dually. He has the SRW 10.5 which is only available with 3.73 in a PSD
I was only talking about his truck specifically. That's why I mention Superduty by name because I don't know if the PSD vans are offered in different ratios.
Old Aug 25, 2003 | 09:04 PM
johnsdiesel
Missing Axle codes
One of the things I like about my 97 is that it came with a 4.10.
Old Aug 26, 2003 | 10:16 AM
backnblack00's Avatar
backnblack00
Missing Axle codes
My truck has a blank space under AXL on the pillar as well. Looks like it was printed that way from the factory. However I know my vehicle had been modified before I bought it because the numbers on the diff tags read that I do not have posi. and I sure DO have posi. Also I am pretty sure that 3.73 was not the only axle ratio available on superduty f-250s from the factory, now this may vary depending on the year. The Ford truck FAQ at the top of this forum has a link to a calculator where you can get an idea of your gear ratio by inputting your rpms at 60 mph ( maybe tire size too).
Old Aug 26, 2003 | 02:35 PM
RRMike's Avatar
RRMike
Missing Axle codes
For SRW PSD's it was. For gas motors or duallies there are other ratios. Unless this has changed in the new 04's.
Old Aug 26, 2003 | 03:35 PM
backnblack00
Missing Axle codes
Oh that's what PSD stands for, I thought it meant "Pink Super Duty".
KLEO1480
Mar 2, 2013 06:53 AM
kjgibson2
Jun 9, 2011 11:22 PM
SomeDude451
Aug 26, 2005 12:45 PM
mc
Nov 2, 2004 12:20 AM
Jim McCarty
Jul 22, 2003 06:33 PM
