CrankShaft Bolt
Old Aug 25, 2003 | 01:36 PM
MCPhilpot's Avatar
MCPhilpot
CrankShaft Bolt
Anyone know if the crankshaft bolt on a Ranger 2.3L is counter-clockwise to tighten or clockwise?? I am trying to replace the timing belt on my 4 cylinder and the only thing holding me back is getting the crankshaft bolt out so I can get to the other cover to replace the belt.
Any help would be appreciated!
Mike
Old Aug 25, 2003 | 08:18 PM
Ken00's Avatar
Ken00
CrankShaft Bolt
Welcome to FTE!!!
I'm someone with a 4 banger will be able to help.
Old Aug 27, 2003 | 08:01 AM
gdoggy's Avatar
gdoggy
CrankShaft Bolt
Counter-clockwise to loosen just like a regular bolt. If it's a 5-speed and you are using anything other than air tools, you will want to have the truck in 4th gear when you loosen the bolt. A cheater bar is helpful too.
Old Aug 29, 2003 | 08:34 AM
sstarkey's Avatar
sstarkey
CrankShaft Bolt
I just changed mine in the parking lot at work. I didn't have any power tools, so I had a 1/2" drive on it (22mm btw) and a 4ft piece of pipe on the ratchet for a breaker bar. I took off the pulleys and put a big set of Vice Grips on the little tangs and wedged those against the stationary pulley above it so the thing wouldn't turn (had it in gear too). Worked just fine.
Old Sep 3, 2003 | 07:16 AM
NakedDucks's Avatar
NakedDucks
CrankShaft Bolt
I replaced the timing belt on my 86 2.3 w/out removing that.
Old Sep 5, 2003 | 04:19 PM
MCPhilpot's Avatar
MCPhilpot
CrankShaft Bolt
Thanks to all that replied, the help was most appreciated. When I used to own & work on Chevy's the Crankshaft bolt was lefty tighty & right loosy, so I just wanted to clarify.
Tried the airgun, but the compressor didn't have enough power, so I tried a large piece of pipe, which powered it out in no time.
Thanks again!!!
Mike
Keg1973
Apr 13, 2015 07:11 PM
shadowalf
Dec 18, 2014 03:40 PM
jpbecker
Apr 1, 2014 08:26 PM
Gettysburg150
Mar 11, 2014 02:59 PM
otisdent
1997 - 2003 F150
Jan 7, 2014 06:36 PM
