79 Body swap
Old Aug 25, 2003 | 12:25 PM
Casey79's Avatar
Casey79
79 Body swap
I have a 79 250 4wd with auto trans and want to switch bodies with a 79 150 2wd auto trans. I think this will work but I'm not sure if the body mounts are the same and also will the floor board have to be cut out of the 2wd to accomadate the transfer case lever. Help.....
Old Aug 25, 2003 | 08:52 PM
willowbilly3's Avatar
willowbilly3
79 Body swap
Casey the guys in the 73-79 section might be of more assistance but if both trucks have the same sized hump in the floor you should just be able to switch the tunnel cover which is where the hole for the t-case shifter is located. Some of the older trucks had a high tunnel and some had a low one. If the 4x4 has the high tunnel and the 2wd has the lower one then you are in for problems and may want to reconsider unless you are good at sheet metal work.
chirvs
42
Feb 16, 2019 05:04 PM
fordguy98
Apr 14, 2017 11:28 PM
Twiztedjester
Aug 28, 2016 03:15 AM
gtc'sf150
Aug 16, 2015 09:49 AM
Hotrodder
Jan 3, 2005 02:49 AM
