Fuel Pressure
Old Nov 28, 2016 | 03:28 PM
Reddman's Avatar
Reddman
Fuel Pressure
Hi all, my 78 f350 has not been running very good lately. I noticed the coil wire would arc every now and then so I went and got new plugs, wires, cap & rotor. Started it up and ran fine for about a minute. Thinking maybe the fuel filter is dirty so I bought a new one, only clear this time so I could see the fuel coming thru. what I noticed is the filter is not staying full after about 15 seconds after starting. So that leads me to thinking about fuel pressure, what should it be? I am going to pull the tank(thank god it's a dump bed) to make sure I don't have any blockage there. Once that's done the last thing is a weak fuel pump correct?
Thanks for any help.
Reddman
Old Nov 28, 2016 | 04:19 PM
RileyCarroll's Avatar
RileyCarroll
Yeah probably, I'd bet on that before blockage really. But since it's a dump it never hurts to check
Old Nov 28, 2016 | 06:04 PM
Filthy Beast's Avatar
Filthy Beast
Stock Ford fuel pumps put out ~ 7-8 psi.
Could be the pump's diaphragm is old, brittle and cracked. Take a whiff of the oil on the dipstick. Smell like gas?
Not good if it does. Time to change the fuel pump, oil and filter.
Old Nov 29, 2016 | 08:18 AM
Reddman's Avatar
Reddman
Thanks Filthy Beast, I thought it was around 7 PSI but couldn't remember. I'll check it out tonight if I have enough daylight & it isn't raining cats & dogs. Got to love the weather of the northwest.
Reddman
Old Nov 29, 2016 | 04:01 PM
Filthy Beast
You're welcome. Trade ya the weather there for the cold, rainy, windy slop we get here!
Old Nov 29, 2016 | 04:39 PM
PapaBearYuma's Avatar
PapaBearYuma
could also be any of the "soft" hoses connecting the "hard" lines.
before dropping the tank, you might run a temporary hose from the fuel pump inlet to a gas can, just to see that it does "suck" well, and keeps your new filter in its' happy place.
Old Nov 29, 2016 | 05:05 PM
krazyness's Avatar
krazyness
I was also going to suggest checking the lines out first before pulling the tank.
As far as weather though... I'll take rain over the snow were getting (not a ton yet but its coming soon) any day of the week.
Old Nov 29, 2016 | 09:17 PM
Ozzie H.'s Avatar
Ozzie H.
I don't have the '78 shop manual, but the '77 "says" 5-7 PSI for the 300 & 460; and 6-8 for the 302-351W-351M-400; engine temperature "normalized" at idle speed. The minimum volume should be 1 pint in 20 seconds.
Old Nov 30, 2016 | 01:48 PM
Reddman's Avatar
Reddman
Thanks all,
The weather is suppose to clear this afternoon, Hopefully I'll have time to check this thing out. Their calling for snow over the weekend I'd sure like to get this done before then. I just built a spreader tail gate for this truck & would like to get that done to.
Reddman
McDonous
15
Oct 22, 2011 08:43 PM
ravens fan
Jun 23, 2011 01:03 PM
uemf
Aerostar
24
Sep 24, 2008 05:02 PM
willbd
24
Aug 3, 2008 05:58 AM
rjlucas
Dec 24, 2007 10:23 PM
