Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Electrode Storage
Old Aug 25, 2003 | 11:25 AM
Fordzlla's Avatar
Fordzlla
Electrode Storage
The wife dragged me to an auction sale this weekend..... Now I am the proud owner of a slightly used Lincoln Buzzbox welder
Since my woorkshop is unheated and fairly damp, i'm looking for some ideas on storing electrodes so that they stay dry and usable. I've seen an old refrigerator used with the light rigged up to stay on inside, but that was in a commercal welding shop, and would be a bit too big for me.
One idea I had was to use an old cooler to keep them in. I'm not sure id that would keep them dry over a period of time.
Another idea i had was to make a sort of electrode oven using an old freon tank. I was thinking of cutting one end off and either makinbg it into a door, or fabricating a new door, then build a few shelves inside with some sort of grating, and finally putting a lightbulb inside either controlled by a thermostat or a timer( i have a bunch of these lying around from old refrigeration equipment)
Any other ideas/ suggestions??
Old Aug 25, 2003 | 11:28 AM
GR8Diesel's Avatar
GR8Diesel
Electrode Storage
Any airtight container with silica-gel should work. Just remember to recycle the silica-gel periodically.
By recycle, I mean that you can dry silica gel in you oven so it can be reused. I can't remmber what temp and time though.
Old Aug 25, 2003 | 01:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Electrode Storage
I use an old army surplus ammo can that has a gasketed top and a container of dessicant.
Old Aug 25, 2003 | 08:21 PM
monckywrench's Avatar
monckywrench
Electrode Storage
Ditto on the .50 cal ammo can, since it holds two full boxes of rods.
For small amounts, the commercial tubular rod containers are cheap and work well.
Old Aug 25, 2003 | 09:47 PM
SPFDRum's Avatar
SPFDRum
Electrode Storage
Find a small old refrigerator with a good seal. Remove the compressor and etc, install a 100W bulb and you have fairly large and dry storage place.
Old Sep 1, 2003 | 10:12 PM
rwr's Avatar
rwr
Electrode Storage
I worked as a welder on several power plants, our rod boxes were nothing more than 3/8 plywood lined with foil inside, and a 100 watt light bulb, dont buy any more rod than you can use in a month and only take out what you need, any of the lo/high rods begin with a 70, 80, or 90 are espicilly susceptable to moisture warm with torch first, the penetrating rods start wth a 60, the flux degrades pretty quickly, again heat with a torch before using, if any show a powdery residure through em away, thats oxidation that will be in your weld,
Old Sep 2, 2003 | 08:12 AM
Fordzlla's Avatar
Fordzlla
Electrode Storage
Originally posted by rwr
[B]I worked as a welder on several power plants, our rod boxes were nothing more than 3/8 plywood lined with foil inside, and a 100 watt light bulb, dont buy any more rod than you can use in a month B]
Thanks,
I think i'll try that . I have lots of plywood lying around , and some sheet aluminum flashing to line it with. Problem is that a 5 lb box of rods will certainly last me for more than a month, and i'd like to have a couple of different varieties around.
Old Sep 3, 2003 | 07:10 PM
rwr's Avatar
rwr
Electrode Storage
go to a welder supply they will sell you rod by the lbs. makes a lot easier to keep several in your box, the only rod i dont keep is ni-cor which is used to weld cast iron only by that you need it
Old May 26, 2004 | 07:08 AM
captainal's Avatar
captainal
In my old shop, I kept electrodes in one of the plastic boxes with a "snap on" top, on a shelf and not on the concrete floor. On top of the woodstove in the shop, I had an approx. 12'' length of 4" I-beam. In the wintertime I would start up the stove and place a handful of the rod of choice onto the I-beam to drive any moisture out of it before I started welding, of course the rods got fairly warm, but I was wearing my gloves whenever a fresh rod was needed... it seemed to work quite well.
Old May 26, 2004 | 07:31 AM
Sberry27's Avatar
Sberry27
Depending on the type electrodes are stored differently. 7018 is the only common one that most guys here would every likely use that is to be stored heated, his is for the DC versions mainly, and its ideal storage condition is at 300F, in a rod oven. If you have an AC buzz box your common rods will be 6011 or 6013, maybe 7014 or 7018AC and these do not get heated storage although if it is super damp a box with a light bulb would work,,, but even better is just to keep the supply in your house somewhere. Put the box under a bed somewhere or in a closet is fine. The 7018 AC rods work really smooth on that machine, both Hobart and Lincoln make them, I believe Lincolns number is LH73 and the Hobart I am not sure but lists them as 7018AC. They sell them at Tractor Supply under the Weldit brand name.
Old May 26, 2004 | 08:00 AM
GLR's Avatar
GLR
I've used PVC pipe and caps , also the Chem lab in HS was throwing out metal containers that test tubes came in, they work well. How about the metal canisters that some booze bottles come in...of course you don't have to empty the bottle contents before using the canister...
Old May 27, 2004 | 08:42 PM
dixon18's Avatar
dixon18
If you've got an AC buzz box, you won't need to heat your rods (6011,6010,7014 etc) I just spend the 7 bucks and buy the plastic container from the welding supply store that has a gasket on it. It keeps 5 lbs of rod dry for about two months.
Chris
Alberta
Old May 27, 2004 | 10:42 PM
Cliford's Avatar
Cliford
Years ago I took a old medal ice box like the one you take camping,and I
.installed a lite socket in it and I put a 15 watt lite in it nice and warm.
