GP relay.....i think.
Old Nov 28, 2016 | 02:46 PM
The_Josh_Bear's Avatar
The_Josh_Bear
So the switch is unplugged from under the dash?
That's a weird kind of short then...
Old Nov 28, 2016 | 03:22 PM
Jarkill's Avatar
Jarkill
yeah. Kinda strange. Does the ECU only operate the transmission? Or could it effect whats going on here?
Old Nov 28, 2016 | 04:00 PM
tjc transport's Avatar
tjc transport
i ain't rite
trans only. try taking the power lead off the glow plug relay and controller. the relay or controller may be hanging up causing a power backfeed.
Old Nov 28, 2016 | 04:11 PM
Jarkill's Avatar
Jarkill
Thanks Tom. Thats kinda why i titled the thread the way i did. Im gonna try that next. Is it the white wire?
Old Nov 28, 2016 | 08:33 PM
The_Josh_Bear
The white wire is what activates the relay. I think Tom means the main power wire to the relay, which should be the two sandwiched yellow 10 gauge ones.
Old Nov 28, 2016 | 09:36 PM
Jarkill's Avatar
Jarkill
Copy that. Im gonna get on that first thing in thw morning thanks Josh_Bear
Old Nov 28, 2016 | 11:34 PM
The_Josh_Bear
While you're under the hood, trace the wires back to the connector they run through on the passenger fender. It's like an 8-port connector with the two yellows in and out, I think it's covered in loom normally. Due to the current they draw and the crappy plastic Ford used in this era it's a common melting point. May even be where the short is!
Best thing to do is cut them out and connect them together outside the connector to keep shorts/melting from happening later.
Old Nov 29, 2016 | 03:29 AM
tjc transport
i ain't rite
correct. the white wire is the ground/trigger wire for the relay. disconnect the two yellow power feeds.
Old Nov 29, 2016 | 10:12 AM
Jarkill's Avatar
Jarkill
Will do. Thanks for the tips guys! I'll let you know what i find
Old Nov 29, 2016 | 11:50 AM
Jarkill's Avatar
Jarkill
I disconnected the main power from the glow plug controller and it is still energizing.
Old Nov 29, 2016 | 11:58 AM
Jarkill's Avatar
Jarkill
Could have something to do with it....
Old Nov 29, 2016 | 05:03 PM
Jarkill's Avatar
Jarkill
That was it! She's back on the road again. Thanks for your help fellas!
Old Nov 29, 2016 | 05:57 PM
  #28
tjc transport
i ain't rite
cool beans!!!! so the power leads in that there plug were shorting out and causing all your gremlins??
Old Nov 29, 2016 | 06:27 PM
  #29
Jarkill's Avatar
Jarkill
shure was! It melted through and the wires right next to the main power wires were making contact causing a back feed of some kind
Old Nov 29, 2016 | 11:13 PM
  #30
The_Josh_Bear
Nice! I love it when a plan comes together!
RBerry9511
Feb 7, 2020 04:31 PM
afonda
Apr 10, 2018 06:39 PM
mounddog
20
Aug 9, 2008 09:31 PM
Motorhead26
46
Feb 20, 2007 06:40 PM
Hit Man X
Jan 28, 2003 12:27 PM
