Intermittent rough running
Old Nov 24, 2016 | 08:31 PM
fearfactory's Avatar
fearfactory
Ok, so I have a 2004 F250, with 6.0L. when driving at a steady speed (doesn't matter what speed), the engine will run rough when coming to an idle, and stay running rough until I shut it off and let it sit for a bit.
After I cycle the key a few times it will fire up and run fine, so I came to the conclusion that air is getting in the fuel system. I then took the filter cap off that is located in the engine bay and cycled the key, which produced a lot of bubbles, which I am assuming shouldn't happen.
I guess my question is, should I have air bubbles in the filter bowl, when cycling the ignition?
I apologize in advance if none of this makes sense... Thanksgiving and drinking, have my mind in different places
Old Aug 3, 2017 | 09:49 PM
Simps's Avatar
Simps
What did you find to be the problem?... Solution?
txtruck44
Apr 23, 2011 02:23 AM
roushcm
Jan 31, 2010 07:51 PM
89Wrangler
Feb 7, 2006 05:51 AM
KevinJ
Nov 8, 2004 11:08 PM
