Thermostat?
Old Nov 25, 2016 | 04:34 PM
RileyCarroll's Avatar
RileyCarroll
Originally Posted by meangreen92
Could be the blend door inside the heater box.
i hope this works, gonna try it out tomorrow. Blend door?
Old Nov 25, 2016 | 05:31 PM
meangreen92's Avatar
meangreen92
Whatever they're called. There should be a door which diverts air through the heater core. And another which diverts between the floor and the defrost vents.
Was your truck built with AC?
Old Nov 25, 2016 | 05:48 PM
RileyCarroll
Yeah, it's factory I believe
Old Nov 25, 2016 | 10:11 PM
Ozzie H.'s Avatar
Ozzie H.
Originally Posted by RileyCarroll
I have a 1973 f-100 with a 302 and factory air (I think). It now seems to run a lot cooler but it never gets to operating temperature. It used to go about 5/8-3/4 of the way up the gauge with the old radiator, but still stayed well within normal range. Now the needle barely moves. At first I just thought my gauge was inaccurate, but now it's getting colder and my heat isn't really working that well, so I'm thinking thermostat.
The heater function may be a separate issue from the operating temperature of the engine. As mentioned, things like an air door or heater water control valve could be the problem for the heater. As far as the engine's operating temperature goes, perhaps using a known good thermometer would be an accurate indicator. It's hard to imagine that the engine will not warm up if the thermostat is closed, unless you live in a really cold place.
Old Nov 25, 2016 | 11:18 PM
RileyCarroll
it could be, and probably is. I need to buy a thermometer to check it. I've been hoping that gauge was accurate because it used to read much higher with the stock radiator. Now the needle barely moves, makes me nervous that the engine could've been overheated, leading to head gasket issues
Old Nov 26, 2016 | 12:07 AM
Tedster9's Avatar
Tedster9
When engine is good and warmed up and heater is running check that both heater hoses are hot. If not, that indicates a blocked heater core.
Old Nov 26, 2016 | 12:02 PM
RileyCarroll
I'll try that, the new thermostat worked and it now gets up to normal temp. I'll check the heater hoses when I get home in a bit, thank you all for your help
Old Nov 26, 2016 | 12:24 PM
RileyCarroll
Tried the hose test, they are not hot. Room temperature air coming from the vents
ill look into replacing the core and go from there, thanks guys!
Old Nov 26, 2016 | 02:17 PM
Ozzie H.'s Avatar
Ozzie H.
Could also be a problem with heater coolant valve, air door, or control.
Old Nov 26, 2016 | 02:41 PM
Tedster9's Avatar
Tedster9
I'd try unblocking the stoppage before tackling a heater core replacement, depending on the rig it can be a &%#ing Pain dè Royale.
Try backflushing with a garden hose or shop air, something like that, if you have it.
Old Nov 26, 2016 | 04:05 PM
RileyCarroll
I'm going to flush the lines and check all of that just in case. I don't want to replace that core if I don't have to
Old Nov 26, 2016 | 04:08 PM
RileyCarroll
that's what I'm going to do, maybe that's the problem. First I'm going to take the hoses off and flush them, then try and flush out the core somehow, if that's possible
Old Nov 26, 2016 | 05:27 PM
  #28
Tedster9's Avatar
Tedster9
The hoses are probably clear? Try to determine the inlet and outlet hose. Backflush or, direct a strong stream of water in the opposite direction of normal flow. Think heater hose is 5/8"? Maybe a female garden hose end could be temporarily installed. Betcha a bunch of crud gets dislodged. Even if that's not the problem, it probably needs it anyway.
Old Nov 27, 2016 | 10:29 AM
  #29
RileyCarroll
The heater control valve coming off the inlet hose looks old and rusty, how can I check it?
Old Nov 27, 2016 | 01:02 PM
  #30
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D4AZ-18495-A (replaced C7SZ-18495-A & D1AZ-18495-B) .. Vacuum Controlled Heater Water Valve (Motorcraft YG-136) / Available from Ford
1973/79 F100/350 & 1978/79 Bronco with factory installed integral A/C // With factory A/C: 1967/76 Thunderbird; 1969/73 Mustang/Cougar; 1969/78 Galaxie/LTD.
1972/76 Torino/Ranchero; 1974/78 Pinto/Bobcat; 1975/91 Econoline.
