Resealed steering box
Old Nov 24, 2016 | 02:43 PM
Justin73supercamper's Avatar
Justin73supercamper
I have been plagued by a leaking steering box since I bought my pickup. Finally ordered parts from Napa 27 bucks. I bought a seal kit for the input shaft and Pittman arm shaft seals. About three hours total I had them changed. The little repair shop down the road from me told me to put the box back in with the Pittman arm off and the retainer ring out and start the truck and turn the wheel to lock and blow the Pittman arm seal out. It works great . I wish I would have taken pics but didn't to lazy I guess. But so far no leaks. The hardest part was getting my steering wheel center again. If anyone wants I will post the pics of the boxes and part numbers. A easy fix inexpensive and may delay having to buy a remanufactured box.
Old Nov 27, 2016 | 03:30 PM
ola1234's Avatar
ola1234
Post them. Don`t need them right now, but I am sure I will once. For 27 dollars it could be ok to have the parts ready on a shelf in the garage.
Old Nov 27, 2016 | 06:50 PM
Justin73supercamper
Here they are
Old Nov 27, 2016 | 06:54 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Part #'s and directions have been right here the whole time....just saying. https://www.ford-trucks.com/forums/1...l#post14696828
Old Nov 27, 2016 | 07:48 PM
Justin73supercamper
I remembered seeing post about it. I'm very computer illiterate so I searched couldn't find what I needed so I just dove in. I wrote my post basically to say how easy it really is and to at least give it a try . And Mike I remember your name in those post also. Giving great advice.
Old Nov 27, 2016 | 10:36 PM
77&79F250's Avatar
77&79F250
No need to search for the 1st 4 RED READ FIRST threads, that are always there.
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line? It has a drop down search menu arrow, go to the "Advanced Search" option, top left side (search block) type in there what you are looking for and then go to the lower right column and highlight 73-79 forum. Select it and then you will have a detailed search just in the 73-79 forums.
Old Nov 27, 2016 | 11:33 PM
Justin73supercamper
Hey that is something I didn't try. I did mean you 77 79. In my last post about remembering a name giving all the great advice. Looks like I should look around the site and try different things. Thanks for the advice. I appreciate it
Old Nov 28, 2016 | 12:12 AM
77&79F250's Avatar
77&79F250
No problem, yes those red read first threads area ton of info. HIO Silver is that man when it comes to tons of advice. And his is way better organized than mine. lol
Ck out his "Technical Info Hyperlink Compilation" and the one with the "tips and tricks" is a good one to.
Dweber85rc
Jun 13, 2019 01:32 PM
67camaro
Sep 20, 2015 11:36 AM
Stroked Out!
Feb 13, 2007 08:45 PM
manicmech
Nov 17, 2004 08:45 AM
Hit Man X
Oct 15, 2003 07:36 AM
