Does anyone have the pin identification for the c270a plug going into the back of the fuse panel and what fuses it would use.
2005 f250 6.0 lariat
I put a test light on to check for a short and I pulled every fuse and the test light doesn't go out so I started removing the plugs in the back of the fuse block and the light goes out when the c270a is pulled.
Any suggestions are appreciated.
Thank you to all.
