New Brakes, No Pedal While Engine is On
The brakes on my 2000 F-350 have been grinding and pulling my truck to the right since I bought it a little over a year ago. The brakes got scary enough that they would occasionally go out while I was driving, so I bought all new Calipers, Rotors and Pads, and installed them all today on all four wheels.
I broke the line that comes off the master cylinder to the left front, and replaced it. During the process, the master cylinder drained completely. The new line is solid and dos not leak. I refilled the MC, and bled the brakes starting farthest away from the MC, and got all the air out of the lines. The brake pedal is very, very hard when the truck is off. When the truck is on, it goes straight to the floor. The brakes were bad before, but at least I had pedal!
Now I'm trying to figure out how to get pedal before Monday so I can drive it for work. So if anyone has any ideas, please let me know, or redirect me to a post I may have overlooked. Thanks!
UPDATE
RockAuto sent me two right rear calipers it appears, I should have realized the bleeder on the bottom on the drivers side caliper.
But my next question is, would the amount of air in one out of four calipers still cause the pedal to go all the way to the floor? If I slam on the brakes, straight to the floor, I need to have at least 15-20 feet in front of me before I can expect to come to a complete stop. There's no stiffness in the pedal until the very last inch or so.
If the master cylinder drained you probably also have air in the ABS system, you will need a high end scanner like the Ford IDS, there are others that will work also, to do a "service bleed" on your truck, it is the only easy way to get the air out of the ABS system. You also may still have air trapped in the master cylinder unless it was perfectly level when you bled it, that's why bench bleeding is used on a new master before installing it.
Some models of Super duties had one caliper in front and one in back on each side and others had both on the back on the rear axel.... makes it complicated trying to get the correct parts.
smilespergallon79
10-13-2016 06:26 PM
shoeman502
1997-2006 Expedition & Navigator
21
04-12-2008 03:29 PM
highway90
29
11-23-2005 06:20 PM
