Redtop, Yellowtop, Interstate, Costco
Old Nov 28, 2016 | 10:20 AM
TerranE's Avatar
TerranE
That's the problem with warranties. I'm always in an inconvenient place to use them. I was using Walmart batteries when traveling a lot.
Regardless, I've been stuck with bad batteries that had good warranties. You get stuck in a rut, trading in a failed low quality battery for another low quality battery. Warranties only give an estimation of a battery's worth.
Even with a good warranty, they only replace the failed battery.
Both Optima and Interstate used to have good reputations. The Optimas that came with my truck are dated 6 years ago, which I consider a pretty good run. Things change.
Old Nov 28, 2016 | 01:34 PM
dn29626's Avatar
dn29626
I look for batteries with long warranties and high cca's from a retailer with lots of stores in the areas that I travel in.
No battery is going to last forever.
With my truck, so far, each time I have had a battery go bad, the retailer has cooperated with replacing both.
Old Nov 28, 2016 | 01:58 PM
hydro man 17's Avatar
hydro man 17
The battery thing can be a real crap shoot. There are only a handfull of actual manufacturers, and they are sold under a zillion different names and a wide degree quality.
Johnson Controls used to be among the best and they build them for many different "brands" at differing quality levels as well.
There is a web site that breaks all of this down but I do not remember the name of it at this point.
Old Nov 28, 2016 | 03:26 PM
nossliw's Avatar
nossliw
Go look hard at DEKA one more time from East Penn... Look at the manufacturer, chemical/compound origins, and location of manufacturing. Then go compare with every other battery manufactured down in Mexico with chinese chemical/lead/matt.
We now use them and solely DEKA over Optima, exide, etc. Not only in diesels but heavy machinery and marine/RV applications. I have both trucks fitted with the 9A65 AGMs.
Old Nov 28, 2016 | 05:01 PM
Rikster-7700's Avatar
Rikster-7700
East penn also make the Duracell'a sold at Sams club, just a hair over $100 each (group 65 875cca) I believe.....
Old Nov 28, 2016 | 07:27 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I'm entering into my 7th year on a pair of Enersys Odyessey Extremes, 930 CCA.
It isn't just the longevity that I like about these batteries. It is their performance while they are in use, which I find is worth their extra cost, even if they only lasted 4 years, nevermind the 7 years they've lasted thus far. They tolerate deeper discharging, and, they hold on to their state of charge for a longer period of time between charge cycles... which is very convenient for a relatively infrequent use vehicle.
But there are a few things that we expect from batteries that the Odyssey batteries fail to do: They don't leak. They don't outgas. They don't spill. They don't corrode the battery tray. They don't corrode the connections (and I've had all kinds of dissimilar metals attached to the terminals). They don't use water. They don't need water checked.
And, there is one other attribute that many other batteries have going for them that the Odyssey batteries don't. Namely, international travel. The Odyssey batteries have never crossed a border to get into the US. Neither by land, nor by sea.
Old Nov 28, 2016 | 11:14 PM
ZachinCO's Avatar
ZachinCO
Originally Posted by Tugly
I have never liked the Optima batteries in a car/truck. AGM is a fantastic technology in the appropriate application - like a boat... but the trade-offs cannot be ignored. In a boating application, amp-hours are the Holy Grail - and AGMs (like the Optima) suck here. The answer on a boat is get a bigger AGM, but the price of that bigger AGM will melt the ol' Buck$Zooka in a hurry.
AGM batteries in our truck is not the best use of that technology, and there is no up-sizing to add amp-hours (reserve power). Because we don't list several degrees to the side for extended periods (like in a sail boat) and our "hulls" don't slap on the waves (we have suspensions), we can get away with batteries that spill or don't like heavy physical shocks. With that, the flooded cell battery is still the most powerful, has the highest reserve capacity, and is the most reliable when you factor in dollars spent vs performance delivered.
I'm in no way saying AGM isn't the right technology for our trucks - I'm saying we are really let down on the what we get for what we pay factor.
If batteries are starting to go bye-bye under your hood, it may be time to look at the elevctrical system on your vehicle. I just found a corroded battery ground last winter, and I am helping two friends this very weekend with the same symptoms I had - I suspect more corroded grounds.
Which location & what were/are the symptoms?
Old Nov 29, 2016 | 05:10 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
NAPA batteries!
Old Nov 29, 2016 | 05:46 AM
glockholiday's Avatar
glockholiday
I've had good luck with Costco branded Interstates, Interstates and Optimas. But I've been sticking with the Costco Interstates recently because I'm getting the same life at a lower price.
I've gotten 6 years out of each of those batteries and the shortest life was 4.5 years.
I will put nothing but the green and white Interstate Mega Tron Plus in my RV they have great reserve capacity and even with sitting through the winter (with a battery tender) I still get 4-5 years out of them.
Old Nov 29, 2016 | 11:38 AM
Tugly's Avatar
Tugly
Here's a cut and paste:
Slow crank. Intermittent WTS and other lights flashing on dash. Truck dies.
New batteries, alternator, and starter without improvement.
With the engine running, I checked both battery voltages on the posts (not the clamps). Passenger side over 14 volts, driver side 12.0 volts. They should be identical. Clamps on the driver side - 12.0 volts... juice not leaving the passenger side to the driver side. Checked the passenger side positive cable - 12.0 volts, while the posts said over 14 volts. The alternator was sending juice to the passenger battery, but the cable to the driver battery was corroded.
I disconnected the cables, cleaned everything with a wire wheel on my drill, and reinstalled. Truck cranked fast and strong. With engine running, check the voltages on the battery posts again. 12.65 volts and climbing on both batteries. The driver battery needed to charge up, and it was taking a little time for the voltage to rise at idle.
Here's what happened: This particular truck had 3 positive cables - one went to the starter and across the two batteries, one came from the alternator, and one went to the electronics on the truck. The one cable to the electronics was a separate cable on the driver side. Without juice leaving the passenger side, the battery on the driver side was powering the electronics without charging up. Once the voltage on the driver side dropped too low, blinking lights and stall.
Old Nov 29, 2016 | 01:35 PM
jgilrfr's Avatar
jgilrfr
imo deka are worth every penny
fnx4wheeler
Oct 15, 2014 01:01 PM
Shake-N-Bake
32
Jun 2, 2012 07:07 AM
Easyfour
6.7L Power Stroke Diesel
Dec 12, 2010 08:57 AM
just another truck
Jan 6, 2009 09:07 AM
boxcar1974
Car/truck Buying Advice
Mar 30, 2006 01:06 PM
