2000 PSD Shutters when cold
Old Nov 22, 2016 | 08:11 AM
Phantomz's Avatar
Phantomz
Truck is a 2000 7.3 PSD Exursion, 300k miles, automatic.
Does this when cold, I let warm up for 5 minutes before this happened as its been doing it. Going to plug in tonight, was about 40-50 degrees out. (Mississippi)
What do you guys think is causing this shutter? Injectors? After I get off my dirt road to street it runs fine, also notice the ebpv. Seems to do shutter most when reversing.
Thanks, Mike
What do you guys think is causing this? Injectors? After I get off my dirt road to street it runs fine, also notice the turbo waste gate? Seems to do it most when reversing.
Thanks, Mike
Old Nov 22, 2016 | 10:48 AM
knottyrope's Avatar
knottyrope
injector armature clearance is not in spec maybe
why
http://dieselpro.ca/Poppet%20Valve.pdf
parts
INTERNATIONAL T444E / DT466e / 1530E injector tune up SHIM KIT w/ IP Tools | eBay
Old Nov 22, 2016 | 01:16 PM
Phantomz's Avatar
Phantomz
Originally Posted by knottyrope
That might be it, no white smoke and starts/idles easily, only when driving does it do it.
Old Nov 29, 2016 | 05:11 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Check ICP for oil in connector.
I just rebuilt top of injectors with the shims... that's an easy job. Mine ran rough as hell while cold...until oil warmed up, then all the injectors operated ok.
My 2 cents...
jd58980
23
Aug 29, 2022 11:55 AM
ajsemtb
Feb 13, 2018 08:03 PM
Excursion Gary
Jan 6, 2015 09:13 PM
MONAVIERONJON
Nov 18, 2014 09:38 PM
jakemb
May 12, 2006 07:20 AM
