HELP!! Low oil pressure @ idle after cooler housing replacement
I just replaced my cracked oil cooler housing (oil filter end) with a replacement one. I started it up and noticed the gauge reads 0 at idle, but immediately goes to normal past 1200 rpm..
Is my motor ****ed? The replacement oil cooler I put on wasnt in the best shape.. and I wonder if it has something to do with it? I cleaned it out really good..
Is my motor going down right now? Im freaking out a little bit.. Whats going on here? HELP! IS this thing safe to drive?
I dont believe I saw anything missing..
Ok, The guy i bought it from says its from a 97 model, so I Dont think it has the design listed in that link above. Although I dont even know anymore.
the truck runs amazing, there is zero signs of weirdness going on apart from my dummy gauge reading zero at <1200 rpm. I would say it runs better than it ever has before.. so it strikes me as odd this is just happening.
The oil color looks fine, no signs of shavings or a 'sheen' on the oil.
I have to leave town and i dont want to risk taking the truck
I'm fairly certain its the oil cooler or the oil gauge.. but until I replace it i dont know 100%
Ok, this is deserving of an update. After sifting through the links that fordpride posted, I realized this issue is straightforward. The HPOP reservoir isnt seeing enough pressure to switch on the oil pressure dummy gauge (~7-10 psi needed). If the truck actually had zero oil pressure, the HPOP reservoir would drain, and the truck would not start.
I took apart the replacement cooler I put on, and here's what I found:
My old broken cooler on right; cooler I took off truck on left. Can you see the difference in position of the valve? Next pic shows why:
There was no spring in the pressure valve assembly. THE SPRING WAS MISSING.
I was quite relieved and also equally pissed to stumble upon that. I took my backup pressure valve assembly, and re-installed it.
While disassembled, I also shimmed the oil filter bypass too, to ensure that it takes just a little bit more pressure to bypass the filter. I put a washer at the bottom of the opening shown above
Voila! Correct Oil pressure at idle again!
Thanks for the guidance as always!
Godzillamax
11-23-2017 12:31 AM
FLYBOY07
17
09-10-2009 01:00 AM
kitsapcountychopper
04-05-2004 08:56 PM
