Show your ground...
In particular, would you please post a picture of how the negative battery cable on your driver's side battery is connected at the battery? Is there a smaller secondary ground lead that bonds to the body, or is it just one cable to the block under the power steering pump?
I'd really appreciate this. Thanks!
(post, ha ha, I love puns)
By the way, I'm asking because I don't have the benefit of the original factory ground cabling on the driver's side. My year is 2000.
For years, I thought nothing of it. But now, I'm paying very close attention to ground loops, clean and dirty grounds, and the amount of resistance between sensor/signal/module grounds attached to the body and chassis, versus high current starter/charging/glowplug grounds attached to the block and battery.
I have the EVTM, but it is on a disc (from Ford, not a bootleg). A decade and a half ago, I had no trouble reading the font. Two levels of reading glasses later, not even a magnifying glass helps. I appreciate your visual confirmation of what I suspected.
I think I might need to shift my ground, and pull the body ground off of that negative battery terminal, with the goal of reducing EMI. I'm not an EE though, so if anyone else has any input, it is certainly most welcome.
Thanks again SgnAZ, for your speedy response. I know it takes time to post pics, and I really appreciate the time you took to do that.
Interesting that the small adjunct 8 gauge wire on the passenger side battery is the ONLY path to battery ground for the entire body, as far as I have had the patience to determine so far. So the PCM ground, the GEM ground, the windshield wiper motor ground, etc, all end up routing over to the passenger side fender to return to ground. On the opposing end of that cable is a similar 8 gauge wire that attaches to the passenger side frame rail.
In the process of upgrading alternators, I also wanted to upgrade the so called "big 3", which includes adding an additional grounding cable bolted to the back of the alternator. I have temporarily installed a braided strap to the frame, but I'm in the middle of rethinking that right now, to avoid ground loops, and to prevent creating alternative low resistance paths through the frame and body that high current loads to ground might seek.
Larry
What if you did accomplish something, how would you know it? I don't think you would, because success is defined as the absence of problems. And how do you make note of non events?
The G100 and G101 grounds, on the body near the firewall/cowl, have the windshield wiper motor and the PCM in the same ground zone. How often have we heard of CMP (CPS) failures and faults, leaving driver's stranded in the middle of the road way... and we probe a bit further and come to find out it happened during a light rain, and they had their intermittent wipers on. The relationship between the use of intermittent wipers and CPS failure is well known, with many examples. How does the EMI noise radiate from the windshield wiper motor all the way to the front of the engine compartment? I'm not an EE, but I do notice the common ground zone between the PCM and the WW motor at the firewall on the wiring diagram.
So if you never experience a CMP failure... could it be because of how you shifted a ground? How would you know, you know?
Our biggest problem with grounds is that they corrode or get loose - and that makes low current, arcing, and EMI. I was doing a routine check of my GP circuit before winter last year - starting with the ohming the grounds on each battery post (not the post clamp) to the engine block. I couldn't even make it past step one without hitting a problem - the driver-side ground post on the battery showed resistance to the engine block. At first I thought it was the clamp on the post, but ohming each contact revealed a poor driver-side cable connection to the engine block. I had to take out the ground bolt and thoroughly clean the metal on the bolt, the washers, the cable end, and the engine block with a wire wheel on my drill.
While one might think the loose ground on the driver side would not have had an impact because there are two ground connections to the block - the truth is very far from that assumption. It's true the batteries share a common positive cable, but they have only one ground for each battery. If each battery is good for 850 CCA when new, we should have 1700 CCA available to power the GPs and the starter. Lift one ground cable, and we have 850 CCA - because we have taken that one battery out of the circuit.
Good point Rich about how easy it is to have only one battery active from corroded/loose ground. The ground behind the passenger side head is hard to access to clean.
IMHO, because of the cost of replacing a PCM, IDM, TCM, dash module, stereo, nav, engine monitor all the grounds for sensitive circuitry deserve a complete copper circuit. Sheet steel/frame bolted together with potentially rusting bolts does not deliver the long term proper operating voltage for these necessary components.
