EGR System
Old Nov 18, 2016 | 03:17 PM
Claudia Tull's Avatar
Claudia Tull
EGR System
Can anyone explain the EGR System in simple terms? We have replaced 2/4 sensors, now it's the system? I was quoted around $400 for part, $350 for labor. Truck is 2011 F250 diesel. Thanks
Old Nov 18, 2016 | 05:47 PM
bobv60's Avatar
bobv60
What it does is takes inert exhaust gasses, cools them, and adds them into the intake to reduce the amount of free oxygen available in the combustion process. This reduces the amount of NOx formed. This is a short, simple answer. I am sure others can give you the long answer.
One thing to consider is deleting the EGR and all the other emissions, IF you are out of warrantee, and don't have emission testing in your area. The estimate you have to fix the EGR is about 1/2 of a delete system installed.
I am NOT a proponent of removing the emissions systems, but I think its good to look at all you options before you spend your money.
I am planning on deleting my 2011 soon, but mainly because of the extra fuel dumped into the exhaust during the DPF cleaning cycle, and the possibility that it COULD have an negative effect on the cracked/broken valves
Old Nov 18, 2016 | 07:29 PM
senix's Avatar
senix
what is the codes...what are they telling you is wrong.
Some get the cooler clogged. You can take it off and clean then reuse it.
Google it and you should be able to find a few videos on it.
Old Nov 19, 2016 | 06:29 AM
HouseMouse's Avatar
HouseMouse
I would also try and Clean the EGR cooler and associated piping. In a somewhat related story... My friend had a CEL that came on every 10,000 Miles or so on his 454, at that time he needed to clean the EGR valve. Worth a try In my opinion.
pnj442
Jun 8, 2013 10:30 PM
johndeere37055
Nov 14, 2011 04:40 PM
jstarr
Oct 8, 2010 06:27 PM
JaySVX
Jul 14, 2010 01:36 PM
fortex
Apr 22, 2007 05:56 PM
