Overheating
Old Aug 1, 2003 | 02:28 AM
hoser4's Avatar
hoser4
Overheating
1996 f-350 4x4 is getting hot. If I pull a trailer it will get HOT HOT. If I drive under 65 it will not get hot any thing over that and the temp starts to rise. If I slow down the heat will fall. I've changed the thermostat, Gutted the thermo. Flushed radiator, got rid of the catalytic converter, cleaned rad. fins. It has been suggested to change clutch fan but that makes not sense to me as fan does not do much at speeds. HELP PLEASE
Old Aug 1, 2003 | 06:44 AM
Quadzilla's Avatar
Quadzilla
Overheating
When you say you "gutted the thermo", do you mean you made the thermostat inoperative? If so, that isn't helping you at all. The coolant needs to spend a little time in the radiator so it can cool before going back into the block. The cooling system on these trucks is quite efficient, so I'd suspect that you've got a flow problem. Either a blockage, or a weak water pump.
Old Aug 1, 2003 | 11:22 AM
hoser4's Avatar
hoser4
Overheating
Everything I have done has helped the problem but has not fixed it. When you speak of blockage what do you mean? The water pump is less than a year old. I was thinking of using a stronger flush to see if it would do anything. How would you check for a weak pump?
Old Aug 1, 2003 | 01:25 PM
Thumper4995's Avatar
Thumper4995
Question Overheating
Was there any maintenance done to the truck before the coolant issue? ie. radiator flush, water pump replacement?
Old Aug 1, 2003 | 08:09 PM
Brad Deicke's Avatar
Brad Deicke
Overheating
Sorry to get off subject a little bit but how do you like your 96 f-350 psd overall? Im looking to buy one and was curious if i should get the f-250 instead. Thanks
Old Aug 3, 2003 | 10:41 AM
hoser4's Avatar
hoser4
Overheating
To Thumper, nothing done in resent past. Just noticed one day that the temp was running higher than normal.
Love the truck. If your not pulling/hauling heavy loads alot I would go with the 3/4 ton. The 350 ride is not the smoothest thing in the world.
grang46
Aerostar
Jul 4, 2014 10:31 PM
exlabman
May 31, 2014 10:56 AM
Dutter
1983 - 2012 Ranger & B-Series
Feb 20, 2012 02:44 PM
speedbump001
Jun 21, 2011 02:45 PM
houston23
Aug 15, 2003 09:49 PM
