Sponsored by: Auxito
New engine noise
Old Nov 17, 2016 | 09:26 PM
valcwby`\'s Avatar
valcwby`\
New engine noise
So on my way home tonight, my truck started to make a clicking, tapping, ticking noise (depends on who you would ask.) I noticed that it only happens when I'm in gear and hitting the gas. In neutral or park with gas applied, no noise. It's coming from the driver's side. 2001 f-150 5.4L, 150K. My bronco's motor just went out and I can't afford to have this vehicle die on me.
Any help? Thanks.
Old Nov 19, 2016 | 05:15 PM
enriched&beyound's Avatar
enriched&beyound
Any help? Thanks.
I would look the exhaust manifolds over carefully, might be a cracked or bolt head rusted or snapped off? Or it could be the cat heat shield flexing & Or a cracked exhaust pipe near the cat, due to a wore out/loose trans mount? ( BUT check the engine mounts too). Or the internals of the cat are breaking up? or the EGR pipe is letting go? Might be the spark plug has worked it was loose and not completely ejected yet?
Does it do it more when cold? and silences/ diminishes after warmed up?
or doesn't matter & does it all the time warm or cold?
Are you low on engine oil? How does it run otherwise?
You'll need to get a length of hose or long screw driver or mechanics stethoscope and try to narrow down where its is come from.
oachs83
1997 - 2003 F150
Sep 8, 2016 06:19 AM
bruno6491
Sep 16, 2007 07:57 PM
snowman54
1997 - 2003 F150
Dec 13, 2005 01:11 AM
stx_V6
1997 - 2003 F150
Oct 11, 2003 09:46 PM
bill148
Modular V10 (6.8l)
Aug 17, 2003 03:36 PM
