MiniMaxx & LBF setting
Old Nov 17, 2016 | 12:45 PM
PlayersZ28's Avatar
PlayersZ28
I loaded the H&S tunes onto my truck after removing some parts. When I did the initial load I was sure that the low boost fueling OEM option was "0". I left it set at the H&S default of "2". When I reloaded the tunes to lower the LBF it showed "1" as the lowest and said it was the OEM setting. I've tried it twice, once going back to stock and reloading and once just retuning and trying to change the LBF. I have it set at '1" right now.
What are others running for LBF? Is "1" or "0" the OEM setting?
Old Nov 17, 2016 | 02:11 PM
SavageNFS's Avatar
SavageNFS
I don't have mine any more, but I'm almost positive that 1 was the lowest (least amount of smoke) possible after some parts were removed.
Old Nov 18, 2016 | 09:53 AM
PlayersZ28's Avatar
PlayersZ28
Thanks Andre. Maybe my memory is getting bad and I didn't see the "0". Getting better mileage on no smoke on the "1" setting.
Old Nov 18, 2016 | 09:55 AM
SavageNFS's Avatar
SavageNFS
If you run 5, I think you have to hook up your ghost trailer. Pretty sure that's a rule.
Old Nov 20, 2016 | 12:19 AM
Dakster's Avatar
Dakster
On your Fiat, does that mean you have to put the mirrors up?
Old Nov 20, 2016 | 09:04 AM
Andrew010's Avatar
Andrew010
YES!!
Ten Characters
Old Nov 21, 2016 | 06:47 PM
UGA33's Avatar
UGA33
I see what you did there...
Then I raise you an upgraded "up" position mirror setup for our Fiat friends.
Old Nov 21, 2016 | 10:45 PM
allcool's Avatar
allcool
Nope you're probably correct.
The old tunes <2012(iirr), before current updates downloaded/applied, did have 0 lbf setting.
New updated MM Ford 6.7 tunes do not have 0 in low boost fueling option in menu, lowest lbf is 1
Old Nov 22, 2016 | 07:16 AM
SavageNFS's Avatar
SavageNFS
See that's the thing...he's got an original "good" MM, but I'm not sure what software he is running. That's a good point. Steve take note of this.
Old Nov 22, 2016 | 07:19 AM
SavageNFS's Avatar
SavageNFS
Originally Posted by Andrew010
YES!!
Ten Characters
Friends like you...
Old Nov 22, 2016 | 08:20 AM
PlayersZ28's Avatar
PlayersZ28
My MiniMaxx was on the latest s/w I got before they shut down. I was running a tune on the truck prior to delete. Before delete I returned it to stock and then put the delete tune on and left LBF at the H&S default.
It shows "1" as being the OE default now when I load tunes, just not sure why it would have been "0" at the initial delete load and now it's "1" when I haven't changed the MM s/w. It may be that I got the "0" in my head from reading what to set it at and the truck was always a "1".
Old Nov 22, 2016 | 09:42 AM
Andrew010's Avatar
Andrew010
Friends like you...
Where would you be without us??
Old Mar 3, 2017 | 05:08 PM
nitro3421's Avatar
nitro3421
Can anyone detail how to go about changing the LBF settings once the Mini Maxx is installed? I didn't install the Mini Maxx on my truck myself and would like to know how you change it.
rideracelivemx7
22
Jan 19, 2010 02:00 PM
Dustball8504
Mar 13, 2008 07:02 PM
20046.0PSDX
Dec 10, 2007 01:47 PM
blksiryder
Oct 1, 2007 05:31 PM
