Instrument cluster
Old Nov 15, 2016 | 01:39 PM
Dave145's Avatar
Dave145
Instrument cluster
Hey guys, been reading up on swapping out my cluster for some time now. My truck is a 77 F150 with gauges and the wonderful brittle back and a chewed up circuit board. After doing much reading on here, I'm left with conflicting views on this swap. In some threads I read only clusters up to '86 would work (speaking of Econoline clusters), but in other threads I read Econoline clusters up to '91 would work if I switch over my circuit board.
I found a cluster on eBay from a '91 E-150. Great shape with an orange circuit board and new plastic backing piece.
My question is will this drop in to my truck or not? I believe that it should, but if someone could confirm this that would be great.
Old Nov 15, 2016 | 02:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In some threads I read only Econoline clusters 1980/86 (with WARNING LAMPS) would work, but in other threads I read Econoline clusters 1980/91 (with GAUGES) would work if I switch over my circuit board.
You do not have to change the printed circuit board, it's the same 1976/91 with GAUGES.
I found a cluster on eBay from a '91 E-150. My question is will this drop in to my truck or not? .
I've typed the following info a gazillion times in this forum.
1975/79 F100/350, 1975/80 Econoline, 1978/79 Bronco came with cluster backs made of a composition material that can TURN TO DUST before your very eyes!
1981: FoMoCo came out with hard plastic cluster backs for Econolines. These were also the 'service part replacements' for the POS composition cluster backs.
E1PZ-10848-A .. Hard Plastic Cluster Back-Use with Oil & Amp GAUGES / Obsolete ~ Available NOS
1981/91 Econoline. Retrofit: 1975/79 F100/350; 1975/80 Econoline; 1978/79 Bronco.
E1PZ-10848-B .. Hard Plastic Cluster Back-Use with Oil & Amp WARNING LAMPS / Obsolete ~ Available NOS
1981/86 Econoline (no warning lamps in Econolines after 1986). Retrofit: 1975/79 F100/350; 1975/80 Econoline; 1978/79 Bronco.
D6TZ-10K843-B .. Printed Circuit Board-Use with Oil & Amp GAUGES / Marked: D6TF-10C956-BA / Obsolete ~ Available NOS
1976/79 F100/350 / 1976/91 Econoline / 1978/79 Bronco.
Old Nov 15, 2016 | 03:43 PM
Dave145's Avatar
Dave145
Thanks for the reply! Just what I wanted to hear. Definitely clears things up. Swapping in a cluster with gauges so looks like it will be a drop in replacement.
Old Nov 15, 2016 | 04:34 PM
tbear853's Avatar
tbear853
Thanks Bill .........
......... this time I saved it
The last time I had mine out it was "very fragile" as you describe!
hermancm
Jun 20, 2017 07:18 AM
GM4WALLS
Mar 5, 2016 07:27 PM
Nitro901
15
Nov 6, 2014 02:18 PM
77_f250_custom
Oct 13, 2014 05:54 PM
brian1080
Oct 11, 2012 01:37 PM
