Battery Life
Old Nov 16, 2016 | 04:45 PM
05MilMachine's Avatar
05MilMachine
On the dedicated units for ATV's and lawn mowers I have had good luck with the battery tender brand. They even make multiple port units for keeping up with a bunch of small batteries, but I just use one per machine and hard wire the leads to the batteries and use the quick disconnect plugs when I park them. My favorite charger lately is a sears diehard with LCD screen. It goes from 2 amp to 150amp starting with float maintenance charging at all settings. It also has AGM and Gel battery settings to avoid overcharging them as some maintenance chargers can do.
Old Nov 16, 2016 | 06:41 PM
ExxWhy's Avatar
ExxWhy
At 2% per week, it's still no problem to drive once a month as long as you have no other drains. ie disconnected
I've had those maintainers quit and then discharge a battery. Maybe I was lucky.
balingwire
Aug 21, 2023 07:12 PM
CASTMASTER
Mar 13, 2013 08:28 PM
bigunit54
2004 - 2008 F150
18
Dec 6, 2011 11:10 PM
BillyBob69
Dec 7, 2009 12:48 PM
ExpySport
Electrical Systems/Wiring
Nov 16, 2009 10:28 PM
